  #21 (permalink)
Old 08-08-2008, 05:58 PM
layson layson is offline
Originally Posted by blizzardwarrior7 View Post
Have you had experience with either of them?
As already said, your better of with a different brand....But I wouldnt hesitate to put a drop in on my truck, if I had to....My experience is that the full intakes are worse.
There was a drop in on my truck when I first bought it. I could never get the stock air box to close properly... so it was gone first chance I got.
  #22 (permalink)
Old 08-08-2008, 06:02 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
Yes!
when i first bought my truck i had no idea about diesel trucks (years ago) first thing i did was put a K&N drop in... after running it for a couple of months i took it out to clean it and the whole inside of my tube had dust all over it... so yes i have experience with it...... my truck right now has a full Airaid intake and i havent had a problem since...
my work truck 7.3L has a S&B and it works great as well... it also had a K&N when i bought it and i took that piece of crap out of their....
do you have experirnace with full intake kits on a TurboCharged diesel truck?
  #23 (permalink)
Old 08-08-2008, 06:09 PM
fordmugg fordmugg is offline
but isnt it if you dont re-rear and just add a tuner for the lost power you put more strain on your trans with towing?
  #24 (permalink)
Old 08-08-2008, 06:12 PM
Dave Dave is online now
Obama sucks
Thats true if we were looking at bigger than 35 inch tires.
  #25 (permalink)
Old 08-08-2008, 06:14 PM
once again i agree....
i ran 3.73 with 35's for a couple of years and never had a problem... by the time you factor in how much its going to cost to regear and buy the parts it would take years to make up the diff.....
my advice is stick with the 3.73 and buy yourself a custom tuned chip instead....
not to mention your RPMS are lower so you will get better highway miles
-Raul
  #26 (permalink)
Old 08-08-2008, 06:25 PM
Strokin & Smokin Strokin & Smokin is offline
Jersey Strokers, Director
Send a message via AIM to Strokin & Smokin Send a message via Yahoo to Strokin & Smokin
my dad has the k&n drop in filter on his 00 psd for over 100,000 miles and never had a problem.
  #27 (permalink)
Old 08-08-2008, 07:47 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Yea, a drop in K&N doesn't prohibit you from closing the stock air box correctly..
And yes I have had experience with intakes on diesels.....I had a K&N full intake on both my 6.4 and my 7.3, and quickly removed them, and replaced them with drop in K&N filters, and never worried about it....I also had a K&N on my dodge, and than replaced it with a AFE intake, and I also eventually replaced my K&N drop in on my 7.3 with an AFE, and then swapped that to a Ford AIS.
If your going to go with 35's you'll be fine....Driving around with 37"s and 3.73 is not such a good idea, its amazing how fast things will heat up, even just driving around town.
  #28 (permalink)
Old 08-08-2008, 09:14 PM
willypscustoms willypscustoms is offline
k&n drop ins suck they are just flat out horrible period. also i run 37" tires i use to have 4.30 gears ran those gears for about 10k miles, then switched back to 3.73 its not worth it to re gear your diesel unless you plan on running like a 40" or larger tire.
  #29 (permalink)
Old 08-08-2008, 09:17 PM
Obama sucks
Man blizzard you have had alot of trucks for a 19 year old
  #30 (permalink)
Old 08-08-2008, 09:32 PM
DJM DJM is offline
I have 37's and 3.73 gears and everything heats up just like it did stock ,but I don't tow much either.
