  #61 (permalink)
Old 08-09-2008, 08:40 AM
taylorking taylorking is offline
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
then how do you do this on an OBS????????????
  #62 (permalink)
Old 08-09-2008, 09:51 AM
sirnunya sirnunya is offline
10k mod seems worthless if you have a chip. The chip adjusts the ICP so why would you want to mess with the tuning? You don't see the 400+hp guys running a DP tuner(or TW, DI, Elite, etc) and banks 6-gun...which is pretty much an adjustable 10k mod like you're talking about..
  #63 (permalink)
Old 08-09-2008, 01:23 PM
Jake Jake is offline
<-----GTP38R
What if i wanna make it lope though, i could use the resistor to do that even if i have a chip.
  #64 (permalink)
Old 08-09-2008, 01:32 PM
get a lope tune on your chip, or when you order the chip say you want it to lope in some tunes at idle.....
  #65 (permalink)
Old 08-09-2008, 01:37 PM
<-----GTP38R
Hm, retard moment for me.
  #66 (permalink)
Old 08-09-2008, 02:04 PM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
I thot dp and tw is more than just an icp connection???
Its installed in the pcm and changes a bunch of diff things. The edge ez is more like a 10k which plugs directly into the icp...this is just my thinking. correct me if wrong
  #67 (permalink)
Old 08-09-2008, 02:54 PM
TW and DP are. they change a lot of things, including ICP...
the banks 6-gun is the 10k type mod...
  #68 (permalink)
Old 08-09-2008, 02:58 PM
<-----GTP38R
What exactly does a TW chip change, obviously ICP readings and shift points, what else, is that it?
  #69 (permalink)
Old 08-10-2008, 07:13 PM
Southpaw Southpaw is offline
1/20/2013
Originally Posted by cob32187 View Post
Damn right its cheap! Im orderin a pack of 500 resistors for like 12 bucks.
RadioShack.com - Cables, Parts & Connectors: Component parts: Capacitors & resistors: 500-Piece 1/4-Watt Carbon-Film Resistor Assortment
I can experiment to my hearts desire with this baby!
When I did my 10K mod a couple years ago, I think I used a 1/2 watt resistor. Looking at these, there are 1/8 watt and 1/4 watt resistors.
Does anyone know what the difference is?
  #70 (permalink)
Old 08-11-2008, 03:19 PM
samiam samiam is offline
Living on a prayer
I tried a 10K Ohm resistor and the truck shook hard, but ran pretty good down the road. throttle was overly touchy. I didn't have access to an 18K Ohm, but I got a 22K Ohm and it is much smoother, with just a tiny puff of black. Definitely more throttle response. Somewhat messes with the tranny I think, and throttle is still touchy, but it obviously has more power. instead of shoving the wires down into the ICP plug I skinned both wires just slightly, exposing the wires, and slipped the resistor wires down inside tightly, and taped it up. now i need to throw the bb in the fpr and see what happens. i'll only do this until I can call DP Tuner and get the chip, and install guages.
