Old 08-06-2008, 09:04 AM
Jake Jake is offline
<-----GTP38R
In tank mod parts
Where do i go about getting the racor 2 micron marine filter stated in the "guzzle" walk through? And does that filter ever cause problems with too much restriction on fuel flow?
Old 08-06-2008, 10:29 AM
<-----GTP38R
Old 08-06-2008, 10:58 AM
tubular031 tubular031 is offline
My kit from ITP came with a baldwin filter and base. If i was putting it together my self, I would get a WIX setup. fleetfliter or filter1 or napa.
Old 08-06-2008, 11:03 AM
<-----GTP38R
Which filter from wix? How much did the ITP kit cost?
Old 08-06-2008, 11:12 AM
33674 - 2 micron
33406 - 5 micron with drain
33405 - 12 micron with drain
24770 - base
I think the ITP kit was $140 when I got it? now its a little more. WELL worth it! you can never filter your fuel too much! and it made my truck much quieter.
ITP 7.3L Fuel Tank / Pre-Pump Kit
Old 08-06-2008, 12:21 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
just don't run the 2mic before the pump, it can cause the pump to fail due to the restriction on the suction side. Has been known to happen according to what some post.
Last edited by strokin_early_99 : 08-06-2008 at 08:04 PM. Reason: I am an idiot some times
Old 08-06-2008, 12:54 PM
<-----GTP38R
Originally Posted by strokin_early_99 View Post
just don't run the 2mic post pump, it can cause the pump to fail due to the restriction on the suction side. Has been known to happen according to what some post.
Thats the kinda thing i was wonderin. You say "post" pump though, what about pre pump? Like the thingy on the guzzle page.
Old 08-06-2008, 01:02 PM
redstroker_2002 redstroker_2002 is offline
KVFD
i bought the kit through itp also!
Old 08-06-2008, 01:50 PM
<-----GTP38R
Isn't the itp a 2 micron?
Old 08-06-2008, 02:23 PM
I dont know... the WIX cross is a 12 micron. the filter I got from them is a BF1212
