  #11 (permalink)
Old 08-06-2008, 02:37 PM
redstroker_2002 redstroker_2002 is offline
KVFD
Originally Posted by tubular031 View Post
I dont know... the WIX cross is a 12 micron. the filter I got from them is a BF1212
its a good kit!!
  #12 (permalink)
Old 08-06-2008, 02:40 PM
tubular031 tubular031 is offline
I agree. I like it.
  #13 (permalink)
Old 08-06-2008, 04:33 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Pre-filter(before the pump) needs to be the large particulate size, 12mic or 15mic otherwise the pump is sucking so hard it causes the pump to fail prematurely. The post-pump(after the pump) is the 2mic filter.
  #14 (permalink)
Old 08-06-2008, 04:44 PM
KVFD
ya thats why the screens in your tank cause prematurely on your pump as well. it causes restriction.
  #15 (permalink)
Old 08-06-2008, 04:45 PM
binder man binder man is offline
Ok I'm planning on putting on a carter helper pump. should i put it with the stock pump or before my pre (main) pump filter?
  #16 (permalink)
Old 08-06-2008, 07:17 PM
The 2mic filter I run is the 3528 napa, it is only 7" tall where the 3674 is 9 1/2" tall.
The 3405 is 7 1/4" tall so they are about the same size. Here is a pic of my trucks system and how low the duel system hangs down. The running boards are lower then the fuel system.
  #17 (permalink)
Old 08-06-2008, 07:56 PM
sirnunya sirnunya is offline
just don't run the 2mic post pump, it can cause the pump to fail due to the restriction on the suction side. Has been known to happen according to what some post.
I think this is where the confusion began..
  #18 (permalink)
Old 08-06-2008, 08:03 PM
I went back and fixed it.
  #19 (permalink)
Old 08-06-2008, 09:12 PM
Ok so if I install the helper/lift pump, I should put it after the pre pump also correct?
