Old 08-05-2008, 12:43 PM
powerstrokin87 powerstrokin87 is offline
Send a message via MSN to powerstrokin87
Drop Pitman Arm
I have a bigger drop pitman arm right now with my 4" lift. If i take my lift off can i leave the longer pitman arm on?
Old 08-05-2008, 12:58 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
I wouldnt....It really wont help with anything, and it may or may not fit, I know if I put a 4" drop PA on my truck it rubs on the plow mount, and it looks like it would rub even if the mount wasnt there.
Old 08-06-2008, 05:42 AM
the reason i ask its a pain to get on and off ill have to take it somewhere.
Old 08-06-2008, 05:45 AM
TANK'S 250 TANK'S 250 is offline
no ...you can't leave it on...it will screw up your steering angles,..and will mostly likely give you really bad "bump steer"
Old 08-06-2008, 05:51 AM
00strker 00strker is offline
y u gotta take it somehwere get a puller and a impact or ratchet
Old 08-06-2008, 05:55 AM
What he said,.....just go to Autozone and get a "pickle fork"....then do it yourself.
Old 08-06-2008, 06:20 AM
I have one. i couldnt get the stock one off but maybe this one will come off easier.
