  #11 (permalink)
Old 08-05-2008, 01:46 PM
SyN SyN is offline
Got Torque!
I'm looking at gauges now also... alot to chose from... I also like the simple install of the Edge posted above. I have a question.
How accurate are the reading with the edge plugged into the port? Compared to the gauges which are wired direct.
Raul: You will get my business for sure... i will order the pod that attaches to the pillar as well as the egt probe upgrade, will need that for sure.
  #12 (permalink)
Old 08-05-2008, 02:02 PM
CSIPSD CSIPSD is offline
What gauges???
  #13 (permalink)
Old 08-05-2008, 02:26 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
the temp will vary a lil bit..... the trans temp i saw anywhere from 15-25 degrees hotter than what i saw on my autometer gauges (had both analog and digital at the same time)
other than that the boost and egt were identical...
  #14 (permalink)
Old 08-05-2008, 02:30 PM
SyN SyN is offline
Got Torque!
CSIPSD: How in the bloody H3LL do you even concentrate on driving? ROFL...
  #15 (permalink)
Old 08-05-2008, 02:43 PM
SyN SyN is offline
Got Torque!
"the trans temp i saw anywhere from 15-25 degrees hotter than what i saw on my autometer gauges "
I can deal with 15 deg, but 25 is a bit much. Next spring I'm going to pay brain a visit at BTS... So i really would like accurate info being posted. Maybe 25deg isnt that much.
But then again... I really won't be towing but only 1/4 of the time. So I should be ok.
I will order this setup, once i get my new wheels and tires.
  #16 (permalink)
Old 08-05-2008, 02:45 PM
Keep the temps under 220-230 and you will be fine... No matter where the probe is. Use the same red line... With a BTS, you should not see temps over 200 no matter what anyway.
  #17 (permalink)
Old 08-06-2008, 07:30 PM
tennfire tennfire is offline
Does the Edge Insight read the factory temp sensor on the 2002 Powerstroke (F350) or does it use another sensor?
  #18 (permalink)
Old 08-06-2008, 07:33 PM
Hank Hank is online now
C.P.A. Officer
Originally Posted by CSIPSD View Post
What gauges???
Dang man! You have to go to a special school to learn to fly that thing?!
  #19 (permalink)
Old 08-06-2008, 09:19 PM
binder man binder man is offline
csi is your dash black? or is just the lighting?...you can fit one more gauge on the column also lol
