Old 08-05-2008, 06:50 AM
mbechert mbechert is offline
Clutch Pedal
Ok... so here is my problem. Last night got in the truck and took off, as I shifted into second and let off of the clutch, the clutch pedal come about 3" in. higher than normal... alomost to where I could not lift my leg up enough to get my foot on the clutch . Not sure what the deal is. I kept messing with it and the pedal finally stopped where it should, but then this morning did the same thing. Does anybody have any idea what could be causing this?
Thanks
Old 08-05-2008, 07:07 AM
Banshee34 Banshee34 is offline
Doop de doo de dooo
Isn't there a spring on the arm of the pedal? Maybe it's going bad?
Old 08-05-2008, 07:50 AM
Yeah... there is a spring, I am just not sure how it all works yet. Right now I am stuck at work so this evening I will perform some acrobatic moneuvers and get under there and take a look.
Old 08-05-2008, 05:45 PM
Old 08-05-2008, 05:52 PM
SCUFFY828 SCUFFY828 is offline
FORD MASTER DIESEL TECH
the problem is the clip thats holds the rod in the slave cylinder broke, there is only one way to fix it , replace the hydraulic clutch assembly , need to buy the ford ikit that comes prebled and comes as a assembly, you can buy just the slave cylinder , but you will probably never get it bled right
Old 08-05-2008, 06:07 PM
that is going to be no fun at all!!!!!!
Old 08-05-2008, 06:18 PM
its actually very easy , twist and snap out of the trans , twist and snap out of the firewall, , remove assembly , twist and snap both ends back in, snap clutch rod back into slave cylinder and your done, shouldnt take a amatuer over 30 minutes
Old 08-05-2008, 06:19 PM
Jon
Tournaments Won: 1
Posts: n/a
Crap
Thank god! I was worried there. I did my last one in 28 1/2 mins. But that was the 3rd for the week. The first one of the week took me about 4 hours.
Old 08-05-2008, 06:27 PM
for a man that advertises doing this for a living , 28 and 1/2 minutes is 20 too long smart azz
Old 08-05-2008, 06:28 PM
Jon
Tournaments Won: 1
Posts: n/a
Heck
I thought I was doing good. Crap it took me 15 mins to get out of the truck. Dang lift was in the way. I did find the hood lever though! Woo Hoo!
