Old 08-05-2008, 07:28 AM
strokin1011 strokin1011 is offline
running rough
ok here it goes was driving north running around 70 or so and it just started
running real rough no power at all slowed right down to 30 by its self shaken real bad pulled over waited about ten minutes fired her up she ran fine for about half hour then again it did this the 200 mile trip up there and back home any help please if not selling for a dodge.
Old 08-05-2008, 07:38 AM
f250ghost f250ghost is offline
Sounds like some bad fuel or maybe dirty fuel filters?
Old 08-05-2008, 11:11 AM
new oil fuel filters and good fuel still does it
Old 08-05-2008, 11:32 AM
Have you checked all your filters? Air filters, fuel filter, water seperator, etc? If it's not that maybe it's an injector? Im sure someone here knows...heres a bump...
-Ben
Old 08-05-2008, 01:12 PM
SyN SyN is offline
Got Torque!
I know it will cost ya... I would have a trusted mechanic plug his scanner into it... See what codes have been thrown... It will keep ya from getting stranded somewhere in the near future. Might be a sensor. Hopefully it's not a problem with an injector.
Something else came to mind: Your wire harness that is under the valve covers. your connector could be bad... causing a short to the injectors.... the scan will show it... have both sides changed if thats the prob.... my 01 did the same thing... 6months ago... had both harnesses changed... problem solved.
Old 08-05-2008, 01:28 PM
i will have it checked i have a programmer i will check to see if there are any codes no check engine light ever came on
Old 08-05-2008, 02:03 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Its either a valve cover harness thats not connected completely, or possibly your ICP sensor, or IPR, all pretty easy fixes.
Old 08-05-2008, 02:11 PM
screamin7.3 screamin7.3 is offline
I can't imagine any problem bad enough to justify selling a psd to buy a dodge, but i'm a diehard.
Old 08-05-2008, 07:15 PM
drove it tonight ran fine for 2 miles then did it again 30 miles per hour no power and lots of white smoke
Old 08-05-2008, 07:19 PM
thbd77 thbd77 is offline
sounds like valve cover wiring harness....my 96 did that run good then run real rough
