  #21 (permalink)
Old 08-06-2008, 09:38 AM
szyd szyd is offline
Yeah but what about a wing? Mabe one of those 2 step
  #22 (permalink)
Old 08-06-2008, 11:04 AM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
A wing? You mean a spoiler? lol, no.
Go to radioshack and find get yourself a pack of 10k resistors for like a buck.....Find the instructions on where to insert it (inserts into your ICP)....It takes about 1 minute to do....They are on this site in the mod help section near the top of the forum.....You can also just go to google and google "10k mod directions" or similar...
Do the Zoodad mod....Get youself a holesaw in whatever diamter you want, preferable around 3" or so, or you can use several smaller holes....Remove your grill.....Locate where the air intake runs into the radiator support on the right side of the radiator, and drill through the support...Next Cover the hole(s) with mesh of some sort, so that bugs and things cant get in it..
Next, do the wastegate mod.....Simply find the red vacuum line thats plugged into your wastegate, and unplug it, than find a bolt that you can use to plug the line with....Usually the bolts on the Intercooler tube clamps work quite well for this...Try all three of these things to start, your butt dyno will definitely feel it.
  #23 (permalink)
Old 08-06-2008, 12:30 PM
Thank you.
Can you leav the vacume hose off all the time.With no repocusions
  #24 (permalink)
Old 08-06-2008, 12:40 PM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
MINES BEEN OFF FOR ALMOST A YEAR NO PROBLEMS YET
  #25 (permalink)
Old 08-06-2008, 02:00 PM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
HANK told me that on the dyno his truck lost 6 hp with the wastegate line unplugged.
  #26 (permalink)
Old 08-06-2008, 02:11 PM
No repercussion's.
  #27 (permalink)
Old 08-06-2008, 02:16 PM
dallascwbyfn dallascwbyfn is offline
Originally Posted by southern7.3 View Post
well on the stock intake box the plastic runs all the way up to the back side of the grille. If you cut up the stock air box and do the diy intake and the zoodad, it almost makes a ram-air style effect.
I cant get a pic up in a bit if you want to see what im saying
thats exactly what i did, i just have all the air running to the side of the battery straight to the filter
  #28 (permalink)
Old 08-06-2008, 02:21 PM
Powerstroke Fanatic
Yea that plastic piece keeps all the air that the zoodad sucks in and sends it to the filter
  #29 (permalink)
Old 08-06-2008, 02:38 PM
tubular031 tubular031 is offline
Originally Posted by szyd View Post
Thank you.
I ran mine unplugged for a little and it sure felt peppier empty and in the low rpm range, but when I hooked up to pull, it sure felt weaker. usually ill run with the line off then when its time to pull my boat ill pop the hood and stick it back on. try it out and see what you think.
