Old 08-05-2008, 03:08 AM
kb69co kb69co is offline
door ajar light comes on
I have a 2000 PSD and the previous owner had to remove the bulbs from the dome lights because the door ajar light will come on at random and then the battery drains. I have a friend with a 99 and he is having the same problem. I don't see where the contact is in the doors for it. has anyone else experienced this and know how to fix it? Thanks for any help.
Old 08-05-2008, 03:41 AM
horsehauler horsehauler is offline
you are not the first to have this problem, i have known people who have taken there trucks to the dealership and had the swtches in the door replaced to only have it start acting up again after only a short period. i have found the a shot of compressed air in the catch mechanism - clean out any dirt and then a few shots of WD-40 will normaly solve your problems. then once a year or so as preventive maintainence.
Old 08-05-2008, 03:59 AM
So the switch is in the catch mechanism on the door?
Old 08-05-2008, 06:32 AM
yeah boy!!!
Old 08-05-2008, 08:04 AM
Motown Fire Motown Fire is offline
Here is a new question..... Does anyone know how to TOTALLY DISABLE the door ajar dinger and light???
Old 08-05-2008, 10:32 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Take a look through the tech section. I believe it is in there. If not, PM me and I will get the instruction to you.
Old 08-05-2008, 10:56 AM
bigred_stroker bigred_stroker is offline
The best thing that works is to just spray the latch and the catch with white lithium grease. It works wonders. It doesnt always work imediately but give it a few min and then the sensor will shut off. It lasts a lot longer than the WD 40 too.
Old 08-05-2008, 11:02 AM
mine never has worked with the WD40, not in over 5 years.
Old 08-05-2008, 11:06 AM
I would give the W L grease a try (it comes in a spray can if you havent seen it) if it doesnt work then maybe the sensor did just completely S*&^ the bed
Old 08-05-2008, 11:09 AM
I never thought of trying spray white lithieum greese. I carry it in my travel trailer for the slide outs. I will give that a shot
