Old 08-03-2008, 04:40 PM
CUMMINS_KILLA99 CUMMINS_KILLA99 is offline
do you need?
do you need a drop pitman arm with a 4in. lift?
Old 08-03-2008, 04:47 PM
00strker 00strker is offline
yes!!!!!!!!!!
Old 08-03-2008, 05:07 PM
Eric Eric is offline
I HAVE POWAH!!!!!
I would have to say yes. When I put my leveling kit on, my axle set out to the side about an inch until it settled. I assume my pitman arm was pulling it to the side.
Old 08-03-2008, 05:32 PM
daboostcreep daboostcreep is offline
That should have been the trackbar/trackbar bracket pulling it to the side.
Old 08-03-2008, 05:56 PM
to be clear im talking about steering not the track bar bracket ive been told half and half some say i need it others told me i dont
Old 08-03-2008, 05:59 PM
Yes, you need it. You also need a replacement trackbar/bracket. The angle the steering will be at will be completely jacked without a drop pitman. The centering of the axle will also be tweaked to the pass side by 2 or more inches without a relocation bracket and or an adjustable trackbar.
Old 08-03-2008, 06:18 PM
I HAVE POWAH!!!!!
That's what I assumed
TANK'S 250 TANK'S 250 is offline
"do you need a drop pitman arm with a 4in. lift?
99-04 yes
05-07 no
Old 08-03-2008, 06:19 PM
i already have an adjustable track bar wasnt sure on the pitman arm
Old 08-03-2008, 07:16 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Yea, you do, it will be hella hard to steer without one!
