Old 08-02-2008, 05:33 PM
farmboypowerstroke farmboypowerstroke is offline
Changing coolant, need alittle help
got the coolant changed, coolant filter on. I tested the coolant. The molybdate (sp) and the nitrate levels are low, how do i get those levels up? I have an additive, but does it take the levels down? or at least thats what i have been told
Old 08-03-2008, 02:51 PM
SyN SyN is offline
Got Torque!
Have U ever though about switching to ELC? No worries after that. Alot of talk of our powerstrokes cooling system and ELC don't mix. There's a Myth about the seals and the ELC don't see eye to eye. HoG WasH!!
After dealing with that problem for a few yrs. I just got fed up and changed to Red ELC. Don't have to add anything anymore.
If I had an answer for ya, I would share the info. Just one less worry for me.
Took time to share this with ya.. I take my coolant very serious. Mr. Gooch Helped me out here, within another board.
Coolant & SCA Additives!! - Diesel Forum - The Diesel Stop.com
Old 08-03-2008, 03:50 PM
dikdragon dikdragon is offline
ELC?
Can you tell me what ELC is? brand? where to buy? thanx
Old 08-03-2008, 04:05 PM
SyN SyN is offline
Got Torque!
Extended Life Coolant. There a 4 or 5 brands. Walmart stocks Peak Final Charge which is a very good coolant. Try your nearest Diesel Truck Shop. Large Truck Stops. Don't bother with worthless AZ or O'Reillys.=Worthless. Do a search via google on ELC coolants.
I researched the ELC coolant for awhile, and after talking with Mr. Gooch: It was a no brainer. Plus After the addition of a Coolant Filter, I basically tripled the life of my water pump. I just change the filter once a yr. Usually the 1st of Jan. Money Very Well Spent.
Old 08-03-2008, 04:26 PM
choctaw choctaw is online now
I'm #1 in the #2 Business
Sounds like Mr. Gooch knows his stuff, fairly diplomatic considering the previous posts as well.
Thanks SyN.
Old 08-03-2008, 04:45 PM
SyN SyN is offline
Got Torque!
Mr. Gooch is the most honest and respected person that I have met on any of these diesel boards. He has taken the time out of his day, many many times to help me solve a problem with my 7.3L and saved me hundreds of dollars.
