Old 08-02-2008, 05:02 PM
bigjb08 bigjb08 is offline
Question Help again with gauges!
Alright guys, I got everything hooked up and got my new DP chip in. There is one problem though! I have lights to all my gauges and the boost gauge is working fine. The trans temp and Pyrometer gauges are nt working though. They both light up and the needles jump when I start the truck, but they do not read anything even after about ten minutes of driving. Any advice would be helpful. Should I pull them out and start all over?
Old 08-02-2008, 05:04 PM
RadarRider RadarRider is offline
Central Scrutinizer
How are your pyrometer & trans temp gauges hooked up?
Old 08-02-2008, 06:21 PM
They are wired the way it told me too. I have a wire running from sender to the tranmission where the plug gos. I have the pyrometer lines tapped into the manifold and then running back to the gauge. They are gronded together and have the 12 volt wired together. I might have the 12 volt hooked into the wrong fuse spot. I dont know?
Old 08-02-2008, 06:23 PM
2005F250 2005F250 is offline
Check your ground.
Old 08-02-2008, 08:37 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Check your ground x2.
Old 08-02-2008, 09:43 PM
tollen17 tollen17 is offline
Send a message via Yahoo to tollen17
I daisy chained my ground's together and found a ground wire under my dash, cut it and tied the grounds together. On the power side I found the 12v power wire to my dimmer for my dash and cab lights and cut and tied also. so they would dim with my dash lights. Tapped my power from my fuses- kinda helped I used a tester so I knew what I was getting in to.........I hooked up a triple piller
Old 08-02-2008, 10:09 PM
superduty4x4 superduty4x4 is offline
I hooked up a triple pillar from Diesel Manor using their instructions... no issues. Check your ground X3.
Old 08-02-2008, 10:20 PM
jhaddox jhaddox is offline
Send a message via AIM to jhaddox
get a test light and check all your power supplies to make sure their givin the guages the power it needs i know when i did mine i used the quick connects and they wouldnt work. turns out i didnt push the quick connect through the wire enough to get the power from it
Old 08-02-2008, 11:11 PM
somebodyelse5 somebodyelse5 is offline
check ground x4
we should take bets lol.
Old 08-03-2008, 12:12 AM
binder man binder man is offline
make sure ground is good and the hot side is getting a full 12 volts...I put in redpowerstroker's gauges and he wasn't getting a full 12 and they wouldn't work, it was just like you said it would light up and the boost would work since it is mech.
