Old 08-01-2008, 01:58 PM
scraph scraph is offline
Low EGTs??
I am referring to the truck described in my signature. At idle my EGT drops to 200F. Cruising on the highway I see 300-600F. Are my EGTs low? Especially 200F at idle ... should I suspect inaccuracy in the thermocouple or does it seem reasonable for my setup?
Old 08-01-2008, 02:01 PM
Nitrochicken Nitrochicken is offline
Send a message via Yahoo to Nitrochicken
um yeah...something is not right
Old 08-01-2008, 02:02 PM
are you shooting nos all the time LOL........check your thermocoulper connections......where is it mounted? maybe a bad guage
Old 08-01-2008, 02:33 PM
It is tapped pre-turbo into the lowest point on the exhaust manifold drivers side. The behavior of it seems reasonable ... I see no erratic behavior of the gauge. Assuming the connections are good is there anyway to diagnose the faulty component in this circuit?
Old 08-01-2008, 02:48 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
I wish i had 200 degree EGTs . Oh BTW, its off.
Old 08-01-2008, 03:37 PM
binder man binder man is offline
well 200 dg. at idle might not be TO far off....especially if its DP mounted
Old 08-01-2008, 04:43 PM
jblagg jblagg is offline
mine is about 300 at idle that sound a lil low but not too far off. just assume that the temp it 100 higher than the readout to be safe and watch it
Old 08-02-2008, 02:08 AM
SuperDuty1 SuperDuty1 is offline
On a cold engine idling 200* is about right.
Old 08-03-2008, 11:58 AM
pojo4223 pojo4223 is offline
Send a message via AIM to pojo4223
300 is what mine idles at...200 doesnt sound too far off ...you say its mounted in th emanifold which to my knowlege is one of the most accurate positions to have your thermocouple mounted
Old 08-03-2008, 12:00 PM
Eric Eric is offline
I HAVE POWAH!!!!!
Mine reads about 300 at idle but on the interstate at about 65 mph, I only see about 650-700. My probe is in the manifold.
