  #11 (permalink)
Old 08-01-2008, 06:02 PM
mnstroker mnstroker is offline
You want to lose as much weight as possible. A lighter truck will go faster. You could even ditch your spare for the night!
  #12 (permalink)
Old 08-01-2008, 06:09 PM
GM Duraturd GM Duraturd is offline
Also have just enough diesel in the tank(s) to do what you gotta do. Truck full of fuel adds a bit of weight.
  #13 (permalink)
Old 08-01-2008, 06:11 PM
Originally Posted by strokin_early_99 View Post
Drive around the water box, do not go through it and do a burn out.
I can think of a few reasons but what is your explaination for not doing a burnout?
  #14 (permalink)
Old 08-01-2008, 06:16 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
[quote=GM Duraturd;680270]Also have just enough diesel in the tank(s) to do what you gotta do. Truck full of fuel adds a bit of weight.[/QUOTE]
25 gal. = approx. 179lbs.
  #15 (permalink)
DKR DKR is offline
<--Pro Cooler Racer
Dunno about his reason, but I dont do one either. No need with a 4wd launch, and it won't help anyways with the BFG ATs I run. All it'll do is burn rubber off of pricey tires.
  #16 (permalink)
Old 08-01-2008, 06:22 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
First off going through the water box will get the front tires wet and they will loose traction when you launch it. The reason I say don't do a burn out is I want all of my tires to have the same amount of traction. The guys I have seen brake are the ones that do a burn outs and it is always the rear end that brakes. Which tells me the rear hooks up too hard after the burn out. I will get someone to tell me I am full of it but that is my theory and it works.
  #17 (permalink)
Old 08-01-2008, 06:24 PM
I would have enough fuel in the tank that you feel safe that it will not suck air durring the launch. I will not run without less than 1/4 tank.
  #18 (permalink)
Old 08-01-2008, 06:34 PM
Makes sense. I was thinking about not wasting expensive rubber when you will do a 4x4 launch anyway.
  #19 (permalink)
Old 08-01-2008, 08:19 PM
sirnunya sirnunya is offline
AWD cars usually don't go through the water box either. The only AWD car I have seen go through the box did a 4 wheel burnout afterwords. 4 wheel drive launch = no need for a burnout
  #20 (permalink)
Old 08-01-2008, 08:46 PM
PSDfan99 PSDfan99 is offline
Thanks for all the input guys, i sure appreciate it, but we got rained out..... I was all set to go, waiting in line and the rain drops started hitting the windshield. I'll be back another day.
