Just got back from glamis with issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-27-2013, 02:34 PM Thread Starter
So on my way back to San Diego from glamis and out if no where my speedo quit and od light started flashing along with and light. After searching I see it's the rear diff speed sensor. But why did my ac quit exactly at the same time is there any connecting between the 2? My clutch won't cycle on for cold air.
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Stock engine... For now!!!
Hefel86 is offline
post #2 of 6 Old 10-28-2013, 08:37 AM
timmyboy76's Avatar
Bet, Glamis was bada$$...anyway, removethe cover for the streering column, and inspect the wires for any frey, especially the yellow one. You had exact symptoms of my buddys' truck and we found that wire to be the culprit.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 10-28-2013, 09:39 AM Thread Starter
It was defiantly a good time! Did your friends a/c quit at the same time too?
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Hefel86 is offline
post #4 of 6 Old 10-28-2013, 10:08 AM
timmyboy76's Avatar
not sure, since it was in the driveway when it started acting. Do you have pedal response? Any fuses blown?
post #5 of 6 Old 10-28-2013, 03:11 PM Thread Starter
Well replaced the sensor and nothing I guess I'll try and check the steering column for wires
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Hefel86 is offline
post #6 of 6 Old 11-03-2013, 01:37 PM Thread Starter
Well finally had a chance to look into it. Who would have thought 1 10amp fuse would mess up all that. Glad it was an easy fix and puzzled how the tranny speedo/ abs and my climate control all were affected with the one fuze under the dash.
Matt
2000 F250 ccsb 86k
Pro Comp 6" lift
Hefel86 is offline
