02 F350 radio stays on, no power locks - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-26-2013, 07:13 PM Thread Starter
02 superduty F350 radio stays on, power door locks not working
Hello, I have searched this site and numerous others, but haven't found any help due to some people have additional issues or not the same as me. So I figured I would post new.
My truck is a 02 super duty F 350 Powerstroke 7.3. I had a coolant problem a year ago, and just had the truck repaired from it. The truck has sit for the past year not running, batteries would go dead, I'd charge them up and so on.
Now, the power door locks buttons do not work (neither the door lock switches or the remote). When shutting the truck off, removing the key, and opening the door, no doom light, power door locks not working, power windows still work with key out, and radio stays on. The door ajar light stays on when the vehicle is running and all doors shut. The radio and power windows do turn off after the 5-10 minute delay that was common when the truck was shut off and the door not open. I see people say on other sites, it could be the door latches / switch, but if it is the switch on one door, would it not work right on the other doors? (I have tried opening all doors, and still the same results). Some sites and people talk about GEM (WTH is that?), then people say that year truck does not have a GEM. I have also seen people talk about a vehicle security module?
I have the truck scheduled for Ford dealer at the end of the week, but would like to see if I can figure it out before.....thanks in advance.
Last year when the truck first had coolant problems, I took it to a mechanic, who removed the cab to remove the engine, could they not have hooked something upright? Or could it be from the batteries going dead?
Has new batteries and rebuilt engine now.
allaround is offline
post #2 of 6 Old 06-23-2014, 05:43 PM
I have exact same truck and exact same problem have you got it fixed
Bill0318 is offline
post #3 of 6 Old 06-23-2014, 06:21 PM
99bft's Avatar
if it hasnt been done yet then now onto the other. Does your door ajar light stay on after you shut the door?
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #4 of 6 Old 06-23-2014, 07:01 PM
No the ajar light turns off
Bill0318 is offline
post #5 of 6 Old 06-23-2014, 07:33 PM
99bft's Avatar
Hmmm, Without hooking my scantool into it and having a wire schematic in front of me its hard to say. I have encountered 2 trucks doing what you are talking about, one being a 03 f250 with a 5.4 gas truck and the other being a 03 6.0. both ended up being the fuse box in the cab below the steering column and iirc thats the GEM module itself. The gas truck i could unhook the battery for ten minutes and it would be ok for a week or so then it would come right back doing it again.
OTHER TOYS:
65 N600 390
99bft is offline
post #6 of 6 Old 06-23-2014, 07:47 PM
What kind of scanner do I need to test it and what is the gem module
Bill0318 is offline
