headlight conversion issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-25-2013, 04:06 AM Thread Starter
jmaroon's Avatar
i did the conversion to the 06 harley headlights on my e99 about 3 years ago, and used the splice in harness that came with the lights (didn't know there was an adapter) so now, i don't have the stock 9007 end to use the adapter, and i'm haveing issues with the cheap peice of crap splice in pigtail that was supplied.. what do you guys think is the best route? go find a 6.0 and rob the headlight harness and splice it in? or get a 7.3 harness and order the adapter?
e99 F250 7.3 4x4 sb
33" dick cepeks
diy filter - done
gutted ebpv
straight pipe - DONE! .. WOW!!!
later model pcm - soon to be done
guages - next on santy clause list
chip - later on down the road
others in the fleet:
76 IH scoutII
74 IH scoutII
2 73s for parts
93 ranger commuter/beater truck
jmaroon is offline
post #2 of 8 Old 10-29-2013, 09:12 PM
You didn't let us know what problems you're having--but if it is the splice end of the pigtail, can you just replace the splice with a new crimp splice? If it is the other end of the pigtails, can you go to a dealership and buy the stock 2006 pigtails and use good quality butt splices with some dielectric grease?
retiredsparky is offline
post #3 of 8 Old 10-29-2013, 09:22 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I would/did go cut the harness from an 05 truck then you have quality wire and connectors.
No butt splices either that's not good enough IMO especially for lights when every bit of juice counts. Solder and shrink wrap is the way to go. Then tape everything up all pretty and never worry about it again
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 8 Old 11-04-2013, 10:32 AM Thread Starter
jmaroon's Avatar
sorry bout that.. two of the contacts were burnt inside the plug on the cheap one, so i went to the dealership and bought a pigtail for 05.. swiped my card before i realized they had charged me 60 bucks... lol.. soo next time i'll go to the junk yard..
e99 F250 7.3 4x4 sb
33" dick cepeks
diy filter - done
gutted ebpv
76 IH scoutII
74 IH scoutII
2 73s for parts
jmaroon is offline
post #5 of 8 Old 11-04-2013, 01:07 PM
CSIPSD's Avatar
I use butt splices all the time...
Quality is where its at...
The Butt splices I use are crimp, solder and shrink wrap all in one. Strip your wire, crimp them on, heat until the shrink wrap is sealed and the solder melted... The wire fails before the connector does.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 8 Old 11-04-2013, 01:18 PM
Macon's Avatar
True. I would just as soon twist and solder though. I like to visually inspect my work before covering, but...old habits and all of that. If you've had good experiences with those connectors, then I have no experience with them, so I won't say one way or the other.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 8 Old 11-04-2013, 01:44 PM
CSIPSD's Avatar
A true solder connection is great, but these connectors flat rock.
I've installed countless gauge systems with them, done major repairs to wire harnesses...
Never a single issue in 8+ years.
Joe
CSIPSD is offline
post #8 of 8 Old 11-04-2013, 06:55 PM
schlutzer's Avatar
Quoted: 18 Post(s)
For interior stuff I use butt splices or even those self stripping splice connections, especially in area's where soldering isn't practical. Something like lights, or speakers where a connection that's not 100% perfect makes a big difference I'll always choose solder if that's an option.
Also looks a lot more professional and clean looking, aside from where the stuff looks newer, my headlight harness is almost impossible to tell it was modified. I know I would be pissed if I had a stereo installed and found a bunch of butt connectors and ****ty sound.
Stuff like gauges and all that of course connectors are the way to go.
