How many of you guys struggle to start your truck in the cold? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-24-2013, 06:48 AM Thread Starter
I live in elizabethtown PA and it is 42 degree here and I cant get my truck to start. Do you guys think the glow plugs are going out?
New truck in the works
wannatruck is offline
post #2 of 12 Old 10-24-2013, 07:28 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
OH! It's that time-of-year Again - isn't it??
The last two "Stickys" above you will walk you through your Cold Start problems....
Fix it now! It's only gonna get worse
NoRalPh is offline
post #3 of 12 Old 10-26-2013, 06:41 AM
Quoted: 18 Post(s)
Send a message via AIM to rufushusky
Could be the plugs, could be the GPR, could be the UVCH... time to break out the mutli-meter...
Winter Operation, Hard Starting, Hissing Sound Etc...
Troubleshooting GPR & GP's
These trucks, when everything is functioning, really aren't that hard to start in the cold...
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #4 of 12 Old 10-26-2013, 06:59 AM
alaskan155's Avatar
Quoted: 66 Post(s)
i have the same problem, replacing the factory relay with the White rogers 586-902 and my garbage autolite gps with mc zd11 this weekend
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #5 of 12 Old 10-26-2013, 10:34 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Canadian here. I regularly start my truck, not plugged in down to -30C. If everything is working it'll be just fine. Also lighter oil helps a ton
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 12 Old 10-26-2013, 02:24 PM
ScottyP5947's Avatar
Quoted: 2 Post(s)
X2 on the lighter oil - run 5w-40 and check your glow plug system as others directed and you should be in business. I couldn't believe when I first got my truck and I had a really hard time starting it at like 40 degrees...I was pissed, white smoke and stammering while I was late for work! my glowplug relay was bad. Now it starts like a champ no matter what. I never plug in my truck, even when we see 'cold' (10 degrees F, not really that cold). Maybe if I lived back in Buffalo I would put the block heater on a timer so I could get heat faster but wouldn't need to start.
Good luck -
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #7 of 12 Old 10-26-2013, 08:17 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I actually run rotella 10w30 in the winter. Even got my buddy to start doing it with his 95. The difference in starting is immense
post #8 of 12 Old 10-26-2013, 09:20 PM
making sure your glow plugs are working properly, using a lighter oil during the winter (i use 10w-30 in the winter), larger stancor relay, making sure your stock block heater is in working order, and letting the glow plugs heat up properly (they are activated for about 2 min with the ignition in the on position before they shut off themselves) I have no problems starting my truck in our sub-zero temps in the winter, the coldest Ive started up was -32f, it pissed and moaned a little bit, but... it did start and keep running.
the links people posted above are great resources for getting your truck to start up at almost any temp.
natedawgedog is offline
post #9 of 12 Old 10-26-2013, 11:42 PM
eastcoaststroker's Avatar
Plug that bad boy up , My glow plugs are shot but it will start with no hesitation if I plug it up at night .
BIG A lil a ron
03 FORD F250 7.3 POWER STROKE DIESEL
Custom platinum edition paint by G&S Autobody
4inch straight pipe
bully dog triple dog
diy intake
distinct customz kicker system
07 front end converson
eastcoaststroker is offline
post #10 of 12 Old 10-26-2013, 11:47 PM
A lot of people will tell you if it hasn't ever been plugged up don't do it and I agree because its like a baby to a bottle. once you get it on it , it doesn't wanna come off. but I don't mind plugging mine in and it will keep the snow/ice off your windshield .
BIG A lil a ron
4inch straight pipe
diy intake
