What is the long nipple covered by the rubber boot on the WHA for - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-24-2013, 05:55 AM Thread Starter
I will be taking my wheels apart today because when I turn them by hand I cannot feel any wiggle however at the same point in the rotation I can hear something dropping in the wheel hub assembly which makes me think a bearing. when I had the tire off the other day I noticed a rubber boot about 3/4 of an inch tall covering a long nipple almost like an extended grease zerk. What the hell is that for?
2002 F250 Good Old 7.3
126000 miles and counting
Gerald Ford (14 July 1913 26 December 2006)
"A government big enough to give you everything you want is a government big enough to take from you everything you have. "
Tdog77 is offline
post #2 of 3 Old 10-24-2013, 06:30 AM
CSIPSD's Avatar
For the vacuum hubs, I would bet you don't have shift on the fly automatic hubs?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 10-24-2013, 06:32 AM Thread Starter
Ah, ha...You are correct in that I do not have auto hubs and am actually glad. I am going to pull the hubs today and repack them. Thanks for the info.
Tdog77 is offline
