Injector advice - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-23-2013, 01:15 PM Thread Starter
Injector advice
I have a 01 f250 with the 7.3 currently sitting at 193,625 miles and have what sounds like an injector knock. What do I need to be looking for when buying injectors? As far as I know the injectors are stock.
cory5517 is offline
post #2 of 5 Old 10-23-2013, 01:27 PM
CSIPSD's Avatar
First question is... and dont take this the wrong way...
Do you want to fix the problem, or are you just wanting new injectors?
Second question is...
What do you want out of the truck? What are your current mods? How much HP do you want? What is your budget?
Thats alot of questions huh...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 10-23-2013, 01:42 PM Thread Starter
I just wanna fix the problem, I'm all about saving money. The only mods are 4" exhaust and 6637 filter mod. Almost 200,000 miles, how long will these injectors last?
cory5517 is offline
post #4 of 5 Old 10-23-2013, 01:44 PM Thread Starter
How do I list my truck and mods on my profile?
cory5517 is offline
post #5 of 5 Old 10-23-2013, 02:15 PM
CSIPSD's Avatar
I've seen trucks with over 350k on them and the factory injectors... They will last 300-500k if you keep up on maintance.
Your going to have to check for loose rockers, valve springs, do a buzz test and cylinder contrubtion tests. Watch rotational values to see if you can pinpoint an area or hole that is giving you issue.
Joe
CSIPSD is offline
