Mileage ?!?!? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 10-23-2013, 07:43 AM Thread Starter
027.3's Avatar
Mileage ?!?!?
How some of you guys get such good mileage???? I read how guys are getting 14-15 somtimes 16 mpg with lifts and big tires and whatever. I live in south florida (as flat as it gets). I've got a leveled '02 CCSB on 325/60-18's with an 80/tow tune around town I get maybe and I mean maybe 12-13mpg on a great day. On the hwy I might be squeeze out 13.5-14mpg. I drive very conservatively and keep it around 2000rpms on the hwy. So how do you guys do it????
'02 7.3 4 door 4X4 -- Leveled, WIcked wheel,4" turbo back w/ 5" tip, 6637, foil delete, zoodad mod, hutch/Harpoon mod, glow shift Egt & boost, 4- 7" 55w HIDs
027.3 is offline
post #2 of 24 Old 10-23-2013, 07:48 AM
timmyboy76's Avatar
1 on 1 and with less dribble as possible
Try removingthe ebp sensor and tubing and cleaning ur out.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 24 Old 10-23-2013, 12:52 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
make sure fuel filter is clean, every thing else in the drivetrain is well maintained such as differentials, trans case, transmission, motor oil.
try swapping your cps for either a delphi or borg warner cps.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 24 Old 10-23-2013, 01:29 PM
CSIPSD's Avatar
I get 12-14 out of mine... Sometimes 15-16...
Wifes Excursion gets a solid 16...
Make sure your up to par on everything first off... Boost and drive pressure leaks KILL MPG.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 24 Old 10-23-2013, 01:35 PM
codyryan07's Avatar
^^^ what they said, around town i net maybe 12.5-13 depending on how i drive it.. Highway is right at 16 if I keep rpm's just under the 2000 mark.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #6 of 24 Old 10-23-2013, 01:36 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
people lie. I had a 2wd 7.3 ECSB that got 10-11 MPG around town. It did have 4:10 gears in it though.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #7 of 24 Old 10-23-2013, 01:40 PM Thread Starter
027.3's Avatar
What are the signs of a boost leak and what exactly are drive pressures? My truck has 140,000 on the clock. I bought it used with 72,000 miles and have maintained it very well ever since I've owned it. I am putting a WW on it as I've found my stock wheel looks a lil beat up. The WW was a freebie so I figured it can't hurt...I don't think? I also have an ATS housing I just picked up. Maybe I'll throw that on too, or is that to much?
027.3 is offline
post #8 of 24 Old 10-23-2013, 02:09 PM
CSIPSD's Avatar
Do you have gauges?
Drive pressure is Exhaust back pressure, from the motor to the turbo. Drive pressure makes boost. If you have drive pressure leaks from bad up pipes, your MPG will suffer.
As the the WW/housing...
I would install the ATS housing for a fix for surge, and then save up and get the RiffRaff Compressor wheel that is made to go with ported housings.
Riffraff Diesel: Riffraff Diesel Billet Compressor Wheel - Ported Housing
The old style WW moves less air then the stocker for a given RPM, which is why it fixes surge.
Joe
CSIPSD is offline
post #9 of 24 Old 10-23-2013, 03:30 PM Thread Starter
027.3's Avatar
I have a boost gauge. Looking at getting an egt gauge here shortly. My boost is somewhere in the 14-16 lbs area. I see no kind of soot on the pipes going to the turbo but the boots around the spider thing are a little dirty/oily. Is that something to check out? And would it be ok to run the WW with the housing until I can get (might be a lil while) the riffraff wheel? Thanks Kelly
027.3 is offline
post #10 of 24 Old 10-23-2013, 04:14 PM
heisman01's Avatar
Quoted: 53 Post(s)
what tune are you running?
I stay at about 18/19 with my 33's
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
