Question on max temps? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-21-2013, 07:30 PM Thread Starter
Hi guys/gals, I just want to be clear what my max temps are so I do not cause any damage to my 2002 F350 7.3L, 4R100 .
Before any one say, "Do a search" or "It on here a 100+ times" I did. Did I find any answers? Yes. Were they the same? No. Some would say one way then another. So if any of you know the correct or industry standard then please post.
To my understanding the max temps are:
-EGT: 1250 degrees, with the pyro in the driver side rear of the manifold. (where mine is). Someone said International says 1350 degrees is max but 1250 is very safe and can maintain that temp all day. True?
-Trans Temp: 225 degrees with then sensor in the test port. (where mine is)
-Boost: 30 PSI for stock turbo. (Mine is stock)
Thanks for all this great forum help!
godfryness is offline
post #2 of 4 Old 10-21-2013, 08:19 PM
CSIPSD's Avatar
-EGT: 1250 degrees, with the pyro in the driver side rear of the manifold. (where mine is). Someone said International says 1350 degrees is max but 1250 is very safe and can maintain that temp all day. True? More or less true... Its about heat soak. You can go above 1250* for long periods of time, assuming you have not been near there for long periods of time.
-Trans Temp: 225 degrees with then sensor in the test port. (where mine is) More or less yes... If your seeing temps at or above 225 regularly, you need to add cooling capacity and or fix the issue.
-Boost: 30 PSI for stock turbo. (Mine is stock)25 is where your more or less pushing hot air...
See above.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 4 Old 10-22-2013, 08:09 AM Thread Starter
Thank you for the reply. So if I set my gages to alarm at these temps I should be safe or would you set them at a different range?
post #4 of 4 Old 10-22-2013, 08:51 AM
CSIPSD's Avatar
I have the settings on my Isspro gauges set to 1240* EGT, 40psi boost, 200* Trans temp, 220* oil temp, 210* water temp, 220* rear diff temp, 50psi fuel pressure, 20psi oil pressure, and 11 volts...
Joe
CSIPSD is offline
