oil filter leaking - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-21-2013, 07:05 PM Thread Starter
oil filter leaking
Hey im new to this site I had recently purchased this e99 f250 and first thing I did was bring it in to get a oil change. I brought it to walmart and they did the oil change about 1200 miles later I started to notice puddles of oil underneath the truck. When I crawled under there to check things out I noticed the oil was leaking from the gasket of the oil filter. I called walmart they told me to bring it in, It was down 3 quarts so they topped it off and then proceeded to tell me diesel motors vibrate a lot and its very common of the oil filter coming loose "doesnt seem right to me". I left the shop and had to stop to get fuel so I looked under there and yet again still leaking. So can anyone explain to me what might be going on because walmart is telling me I have another problem and there work did not cause this and there not responsible.
Early_99_stroker is offline
post #2 of 5 Old 10-21-2013, 07:23 PM
CSIPSD's Avatar
Go back, and have them replace the filter with a Motorcraft filter. They sell them there.
$9.99 or so.
I have gotten my oil changed there before without issue, its just an oil change, so long as they use Diesel rated 15/40 there is nothing to worry about.
More then likely just a bad filter.
FYI, I buy all my oil change materials from wal-mart. They almost always have the best deal on Delo 15/40 and always have the best deal on filters.
Of course I used to get my oil changed at Jiffy Lube (when the company paid for it) and never had an issue in over a million miles.
3 qts is nothing, the truck holds 14+ so...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 10-21-2013, 08:30 PM Thread Starter
any other ideas of what it could be I had them put another filter on this afternoon same problem leaking, could it just be that fram oil filters suck?
post #4 of 5 Old 10-21-2013, 08:52 PM
blue72's Avatar
Feedback Score: 5 reviews
Yes they do...
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #5 of 5 Old 10-21-2013, 09:20 PM
CSIPSD's Avatar
More or less yes they are not the best. I've used them without issue, but I prefer the Motorcraft ones.
Have you tired tightening them? I never use a wrench on mine, hand tight is all you need.
Joe
CSIPSD is offline
