Fuel leak left side of engine... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-20-2013, 07:04 PM Thread Starter
I have a minor fuel leak. It seems to originate at the rear of the driver's side head. Nothing in the valley. The leak first is apparent on the outside of the head, just at the rear underneath the exhaust manifold. Then runs down the back of the block and forms a drip on the flywheel dust shield. Any ideas? Thanks
99 1/2 CC 4x4 dually Lariat A/T 4.10s w/63k miles
Mods-Tymar intake, DP-Tuner , Autometer gauges, zoodad and 4" Bully Dog Exhaust.
Other toys- 88 Suzuki Samurai 4x4 lifted 6"
Polaris 500 HO RSE 4x4 and Yellow 700 4x4
05 Jeep Liberty Limited CRD 4x4
Gig'em! '86 Texas Aggie
Mykol is offline
post #2 of 5 Old 10-20-2013, 07:24 PM
broncomitch's Avatar
Could have a injector stuck open and blew the head gasket.
My brother had a bad injector and fuel was leaking out of the #5 exhaust manifold.
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #3 of 5 Old 10-20-2013, 07:25 PM
Colin7.3's Avatar
could be the fuel line on the back of the pass head leaking over and down.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #4 of 5 Old 10-20-2013, 10:20 PM
timmyboy76's Avatar
or the 1/8npt plug thats on that side and in that location, thats loose and leaking.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 5 Old 10-21-2013, 02:06 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
if its not leaking from the fuel bowl or fuel lines,
id check the fitting like timmy said. it is a pain to get to, a 5/16 8 point socket is the easiest way to tighten it down, or use vicegrips.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
