leak between tranny and transfer - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-20-2013, 06:21 PM Thread Starter
Question leak between tranny and transfer
Hi Just noticed today I have a leak between trans and transfer. Its definitely ATF. There must be a seal that has failed. Is it a difficult repair?
lght1 is offline
post #2 of 11 Old 10-20-2013, 09:13 PM
usteffenhagen's Avatar
It should be a gasket to prevent leaking between the 2 bolt housings. As for replacement ease? Not too sure I've never done it but if you can manage to remove your t case then I'm sure it can't be too bad
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 11 Old 10-20-2013, 09:25 PM
weicken98's Avatar
No its not hard. The hardest part is removing the upper transfercase bolts. A stubby ratchet wrinch is your best friend after you break them loose.
weicken98 is offline
post #4 of 11 Old 10-21-2013, 07:33 AM Thread Starter
hi thanks. the truck is about to get a engine swap so we will get to it then when engine is out. btw, what would that seal be called ?
lght1 is offline
post #5 of 11 Old 10-23-2013, 08:40 AM
It's a gasket to my understanding. But I'm not sure the exact name
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 11 Old 10-23-2013, 08:41 AM
Call a dealership and ask a tech. That's what I'd do
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 11 Old 10-23-2013, 10:42 AM
Seth14's Avatar
Extension housing gasket on the transmission. The one on the t case is perfectly round, the one on the tranny is different shape....ie flat side and round side. Just put my tranny in :-)
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #8 of 11 Old 10-23-2013, 12:18 PM
I can't tell you what seal you need but I do think you need seals and not the gasket. I don't think that adapter housing is supposed to be full of fluid. The gasket is probably just there to reduce corrosion between the two. I'd say your rear transmission seal or front transfer case seal is leaking.
Matthews is offline
post #9 of 11 Old 10-23-2013, 05:29 PM
alaskan155's Avatar
Quoted: 60 Post(s)
get the t-case to tail-housing gasket from the chevy dealer, it will save you money, ford dealership tries to sell you 3 of them at a time, you will just need to make a hole in it for the alignment pin.
the chevy gasket will work, the bolt pattern is the same, just ask for a 90s transfer-case gasket. for a 1500 silverado
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #10 of 11 Old 10-23-2013, 06:06 PM
Seth14's Avatar
Napa was showing this gasket for $1.00
Seth14 is offline
