? For Those With Riffraff FRx - Ford Powerstroke Diesel Forum
post #1 of 16 Old 10-17-2013, 07:37 PM Thread Starter
Solid98's Avatar
Quoted: 8 Post(s)
Which spring did you use and what is your actual fuel pressure?
I installed the gold spring and am only seeing 55 lbs, running. With the FRx bypassing the internal regulator on the fuel bowl, it makes sense to me the pressure would be lower but I just want to make sure. I'm trying to figure out if my fuel pump is on the way out, maybe (probably) screens in the tank are plugged, or if it is worth the effort to change out to the black spring. Thanks.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #2 of 16 Old 10-18-2013, 06:17 AM
timmyboy76's Avatar
leave the spring in and run WOT runs while watching f/p gauge. See if it dips down. If so, to what #?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 16 Old 10-18-2013, 10:04 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
is your fuel pressure relief worn out as well.
thats another thing to check.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 16 Old 10-18-2013, 10:37 AM Thread Starter
Solid98's Avatar
Quoted: 8 Post(s)
Hose on the gage won't reach to where I can see it while driving.
Solid98 is offline
post #5 of 16 Old 10-18-2013, 10:38 AM Thread Starter
Solid98's Avatar
Quoted: 8 Post(s)
Replaced it with new when I rebuilt the fuel bowl.
Still interested in what others are getting for pressure at idle.
Solid98 is offline
post #6 of 16 Old 10-18-2013, 11:12 AM
timmyboy76's Avatar
i got first gen frx and seeing 70psi. You want to know what it drops to when at wot.
post #7 of 16 Old 10-18-2013, 11:59 AM
Gen II FRx here. 68-70psi at idle, drops to 62, maybe 60 at WOT.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #8 of 16 Old 10-18-2013, 12:34 PM Thread Starter
Solid98's Avatar
Quoted: 8 Post(s)
Which spring? Silver Gold or Black?
Solid98 is offline
post #9 of 16 Old 10-19-2013, 07:13 AM
Black Spring
blderman is offline
post #10 of 16 Old 10-19-2013, 12:33 PM
Quoted: 258 Post(s)
frx is on my list.
my buddy just got one. get a 8 point 5/16 socket, it will make the job sooo much easier.
i snagged his gold spring and am using it but he is using the black spring.
