noisy front end - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-17-2013, 07:12 PM Thread Starter
Thumbs up noisy front end
02 f250, 123k, when I go over dips or speed bumps there is a "rubbing" noise from the passenger and driver side. Does this sound like shocks, or something else? Overall the front end feels tight, good tire wear, steering is good. Thanks for the help.
sean andreano is offline
post #2 of 6 Old 10-18-2013, 04:00 AM
Tugs's Avatar
My 03 7.3 does the same, not sure what it is front end is tight, ball joints are good, shocks are new and steering stabilizer is new. My steering box had a little play in it i tightened it up some and still getting the noise.
2003 7.3 Crew Cab FX4 Mods DIY Intake with AFE BHAF, 4" SS Diamond Eye exhaust, rancho 9000 shocks, 17" chrome Rockstars, Nitto Terragrappler's, Pioneer Headunit, Kicker DS68 door and rear speakers, 8" amplified bazooka tube,Backup camera, factory Ford chrome oval step bars, 08 Super Duty tailgate, 08 tow mirror's, DP tuner Infinity, F5 & CEI hub
Tugs is offline
post #3 of 6 Old 10-18-2013, 12:02 PM
Leaf spring bushings. Replace with poly and it will go away.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #4 of 6 Old 10-18-2013, 12:31 PM
Texas Proud
charlie.thomas's Avatar
Does it have a bump sound as well? If so check your sway bar bushings and the links that connects them to the axle if its 4wd or a arm if 2wd
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #5 of 6 Old 10-18-2013, 01:27 PM
Tugs's Avatar
Where do you buy the poly leaf spring bushings?
Tugs is offline
post #6 of 6 Old 10-18-2013, 03:06 PM
Macon's Avatar
"Rubbing" noise, I would have to say it's worn bushings somewhere. My sway bar got loose, and when I hit bumps it was a pounding noise that made you think a leaf was loose. I jacked up my truck by the bumper until stress was equal and shook everything until I found the culprit.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
