4R100 Transmission To Flush or Not - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-16-2013, 05:42 PM Thread Starter
I have 2000 7.3 with 190K I am hearing some conflicting information. The trans has been total neglected as far as maint. goes I would like to change that, should I flush the tranny or just drop the pan, replace the filter and 8 quarts of Mercon V.
I would feel better about flushing all of the old fluid out but at the same time do not want to some irreversible damage.
Everything in the truck is stock.
Sound advice would be greatly appreciated.
cokerta is offline
post #2 of 19 Old 10-16-2013, 07:47 PM
Quoted: 762 Post(s)
Has the trans ever been serviced? If not, don't touch it and start saving for a rebuild. If its been serviced once maybe twice, just to 8qts and filter.
If a trans had been well taken care of then its just opinion on a complete flush or the 8qts n filter. I never do a flush anymore on my truck per BTS.
My cars I will though.
Corey@CNCFAB is offline
post #3 of 19 Old 10-16-2013, 08:46 PM
usteffenhagen's Avatar
I've always understood that you don't want to do a flush if the trans hasn't been getting them regularly. Or if it's over 100.000 miles.... Or it's the best thing you could ever do to a transmission..... I can never get a similar answer from anyone so I don't think I'll ever get one done. I agree with Corey, just service it.
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 19 Old 10-16-2013, 10:51 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
i need to do this as well.
i thought we werent supposed to use mercon V?
if using convential ATF what are we supposed to put in?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 19 Old 10-16-2013, 10:58 PM
I thought we were supposed to use mercon v....
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 19 Old 10-16-2013, 11:40 PM
Quoted: 249 Post(s)
well apparently originally ford said mercon V was not to be used in these transmissions.
then all of the sudden in like 07-08 they said it was ok.
i cant rememeber exactly ill do some searching
post #7 of 19 Old 10-17-2013, 04:26 AM
Hmm yeah lemme know. I'll probably be doing my trans soon also once I find out.. I might call Ford today and talk to a diesel tech about it
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 19 Old 10-17-2013, 06:07 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
I flushed mine last year. Mercon V
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #9 of 19 Old 10-17-2013, 06:30 AM
Gaius's Avatar
Quoted: 41 Post(s)
If you pull the return line from the cooler and dump in into a bucket, start the truck and let it pump it through. Let it pump a few quarts, shut off. Then top off and do it again until you've replaced the 19-20 qts. Works well, Google E4OD trans flush, theres a good write up on it.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #10 of 19 Old 10-17-2013, 06:34 AM
That's what I would do but I wouldn't do a pressurized flush
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
