7.3 ae test - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-15-2013, 10:48 AM Thread Starter
O.I.F. Combat Vet 11B
7.3 ae test
ok, ran a whole bunch of test with the ae today.
Cold engine...
Chip out- no codes
Chip out- buzz test good no codes twice
Chip in- p1298 code twice
Chip in- buzz test good but with same p1298 code twice
Warm engine.....
Chip in- p1298 until I clear codes then the p1298 will not show up till I run the buzz test.
Chip in Buzz test- ran it a few times with successful test then several times with the p1298 code. Every time the injectors sound loud and audible.
CCT test- came up with something different just about every time it was run.
(2,7,8) one time, (7), another, (5,6,8) another, none a couple times, (7) last time I ran it.
So is this just a phantom code????????? Sometimes it is there sometimes it is not.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #2 of 3 Old 10-15-2013, 07:17 PM
get rid of the chip
sean andreano is offline
post #3 of 3 Old 10-16-2013, 07:52 AM
If you have a spare idm that you know works then try swapping it in. Aside from that, call DP and ask them about it.
Greenman01 is offline
