WTF? Better MPG's in the Hills than flat?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-14-2013, 03:51 PM Thread Starter
I don't post too much, but thought I'd ask. . . why would I get better mileage driving through the mountains at 70mph than I would on flat ground at 65?? Hand calculated. . .16.4 in the mountains, 12.6 on the flats. Last week I took a road trip from northern CA to Yuma AZ, back to San Diego, then to Vegas, then back to northern CA.
Truck is an '03 with a 7.3. . .here's what's been done to the truck-
8"lift, 35" x 12.5 tires
3.73 gears
Injectors- done before I purchased truck, I'm told a little bigger than stock
Tranny/TC/Valve body- new
Cold Air Intake- new
Turbo back exhaust- new
Turbo- Garret GTP38R- new
Up Pipes, Y Pipe, pedestal- new
Fuel Filter- replaced 4k miles ago
Edge set at 100
I would think mileage would be much better on flat ground, with a lower rpm, not working at all. On the last leg of the trip, I fueled up before the mountains and directly after, just to check mileage to see if I was an idiot. Anyone??
Thanks.
bmjt7109 is offline
post #2 of 8 Old 10-14-2013, 04:04 PM
Macon's Avatar
Higher elevation requiring less fuel? If you took I80 back into CA, I really have no idea, unless the partial throttle going back down increased the average that much.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 8 Old 10-14-2013, 04:10 PM Thread Starter
That's what I thought on the first leg of the trip. On the way back, it's a much more gradual climb, for a much longer distance than the descent. That's where I got the best mileage. I dunno. . .
bmjt7109 is offline
post #4 of 8 Old 10-15-2013, 07:44 AM
It's probably a result of different filling levels when you filled up.
Matthews is offline
post #5 of 8 Old 10-15-2013, 08:19 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
That's what I would suspect also. Doesn't seem logical that flat ground, going slower will give less mpg... then increasing speed and engine load results in higher mpgs.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 8 Old 10-15-2013, 07:03 PM Thread Starter
I'd agree, it makes zero sense to me; this is why I paid such close attention on the way back. . . filled till it spilled out(topped off) the last 3 tanks. Would there be anything that'd make the truck run more efficient when it's working harder? Or, more importantly, is it possible that somethings not working correctly(fuel pump/hpop/???) when the truck is under lower RPM's/less boost?
This thing's been a turd since I purchased it. Turbo, pedestal, up-pipes, Y pipe, and tb exhaust made a HUGE difference. Still seems like it's lacking. . .and I'd think mileage would be better. Dunno.
Thanks. . suggestions appreciated.
bmjt7109 is offline
post #7 of 8 Old 10-15-2013, 07:19 PM
SOMETHING WITH THE EDGE MAYBE?
sean andreano is offline
post #8 of 8 Old 10-15-2013, 07:29 PM
Joel's Avatar
Quoted: 10 Post(s)
If your rpms are too low at 65mpg that lugs the motor and makes it less efficient.
Most people report that the 7.3 is most efficient if cruised at 2000-2200 rpm. So if that's the case, 70 mpg might be better for you.
Also, I've noticed a difference in mpg before from one brand diesel to another.
Too many variables to say for sure.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
