high egt's what to do??? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 10-13-2013, 06:47 AM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
I have a E99 that all stock, I put a cat delete pipe on the stock exhaust and have a TS 6 pos chip which I run on the 75hp tow setting. I hauled 14k yesterday and struggled to keep it under 1200. I hit up to 1400 during hill climbs while having my foot on the floor. I get 21 psi & up to 23 psi in the upper rpm range at full throttle. gotta a get this thing cooled down what to do? I was gonna start with a T/B 4" exhaust. what else can I do?
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 31 Old 10-13-2013, 06:55 AM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
Get more air into the engine. Bigger intake like the 6637.
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Dual Firestick Whips, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, Delta Toolbox, Gooseneck Hitch and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
post #3 of 31 Old 10-13-2013, 07:15 AM Thread Starter
Quoted: 2 Post(s)
I was gonna go with the AIS. haven't done it yet though
post #4 of 31 Old 10-13-2013, 08:01 AM
timmyboy76's Avatar
check for soot around the cac boots and up pipes. No need for the exhaust, since your oem is gutted now.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 31 Old 10-13-2013, 08:19 AM
TSbeanspowerstroke's Avatar
is it an off the shelf chip or a custom burned chip from a vendor?
2000 Ford F250 7.3 4x4 158k miles. MODS: Beans Tunes, 4" exhaust, custom twin intake, boost fooler, ported housing w/ Clays 11 blade billet compressor wheel, foil delete, glowshifts 3 in 1 gauge, AIH delete, bellowed uppies
Future mods: banks intercooler, coolingmist, 6.0 trans cooler, BWD blue powder coated valve covers, BWD coated exhaust manifolds.
TSbeanspowerstroke is offline
post #6 of 31 Old 10-13-2013, 08:25 AM
Quoted: 770 Post(s)
I believe riffraff has a nice 6637 setup. IIRC
Corey@CNCFAB is offline
post #7 of 31 Old 10-13-2013, 08:31 AM
an intake might help a little but not 100* worth, build a boost leak detector and check for leaks. and like what was previously mentioned check for soot around uppipes.
if your running canned tunes thats gonna be part of the problem
post #8 of 31 Old 10-13-2013, 08:48 AM
Quoted: 770 Post(s)
I doubt he has any boost leaks as he is hitting 21-23psi. That's spot on for a stock truck at wot.
Run it on the 30hp tow tune. That 75 tow tune is probably for under 6k pounds.
IIRC, a stock e99 is not rated to pull 14k. Only 10k. Especially going up steep hills. Get rid of the muffler too. Or just get the 4"T/B and a 6637. Together they will help around 150*
post #9 of 31 Old 10-13-2013, 08:56 AM
FWIW i could hit 20 psi on a completely stock truck with no tunes, hes hitting 21-23 psi pulling a load at wot should be hitting more boost than that with tunes
he did get rid of the muffler, these trucks didnt come with a cat so he used a cat delete pipe to delete the muffler
post #10 of 31 Old 10-13-2013, 09:05 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
some of these trucks did come with a cat.
although not many of them did.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
