how do I get the livewire to display trans temp? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-12-2013, 09:16 PM Thread Starter
Innovative told me it displays trans temps for the 7 3s but I can't find it. Do I have to install a sensor and wire it to one of the analog inputs?
New truck in the works
wannatruck is offline
post #2 of 12 Old 10-14-2013, 10:20 AM
I can tell you how it works on my 6.0. I run my livewire screen monitoring 9 different vitals. Select the main screen set up and you can change from 3 to 9. Then there is another screen where you select what you want to monitor. I monitor ect, eot, battery volts, ficm volts, boost psi, tranny temp and 3 others.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #3 of 12 Old 10-14-2013, 10:24 AM Thread Starter
My question is, I dont have trans temp as a option when I am on the 3 screen view. I havnt checked the others yet.
post #4 of 12 Old 10-14-2013, 10:36 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
They dont have trans temp sensors in the 7.3 until late 2001 so you will have to buy aftermarket but im not familiar with livewire so im not sure if thats an option to do
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 12 Old 10-14-2013, 11:02 AM
Maybe you will need to call innovative again just to make sure. I know mine has the option and I monitor the trans temp but the livewire wire for the 7.3 may not have the programming to support trans temp. That maybe the case from what was just posted above.
Blue Spring Mod
SCT Livewire ts
post #6 of 12 Old 10-14-2013, 12:20 PM
Seth14's Avatar
My 99 has it on my edge insight.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #7 of 12 Old 10-14-2013, 12:24 PM
Chapter Director
Quoted: 5 Post(s)
Hmm strange im 99% sure that they didnt have trans temp until the big electrical update in late 2001. Someone can prove me wrong though
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 12 Old 10-14-2013, 12:27 PM
Seth14's Avatar
Talking
Now mine is a late model.....but that is one parameter I always monitor. Hoping to see a dropintemps as soon as my bts tranny and 6.0 31 cooler gets here. Ships out on the 16th I was told
Seth14 is offline
post #9 of 12 Old 10-14-2013, 12:34 PM
Macon's Avatar
I'm 99% certain that the PCM has monitored tranny temp in all the 7.3 Power Strokes. OBS and '99-'03. If the PCM is monitoring it, then there is a PID for it, so it should be displayable on a gauge. I believe the useless dash gauge was incorporated in '02.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #10 of 12 Old 10-14-2013, 12:43 PM
Chapter Director
Quoted: 5 Post(s)
Yea thats possible for the SD and i cant for sure say because i have the 6-speed but for the OBS it doesnt or torque pro app wont communicate with it someone can prove me wrong on that one too
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
