2001 7.3 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-12-2013, 06:42 PM Thread Starter
Hi I'm new too this but here it goes I have a 2001 powerstroke it has 140k
It had a hard time starting for a while so I replace the glow plug relay. After
That it worked great for a while the last few weeks its back too starting hard
And now once it fires up idles rough white smoke once warmed up runs great
If not warm runs horrible I was thinking glow plugs but other mechanics are saying maybe injectors... Anyone else had this issue ...
01psd lariat cc short bed..leveled 315 Bfg at motometal. Diy intake 4in mbrp straight pipe. Ts 6pos ... tons more too come ....
kwilson5150 is offline
post #2 of 6 Old 10-12-2013, 08:10 PM
Quoted: 728 Post(s)
If it runs fine after warm up then GP's are probably the culprit.
Corey@CNCFAB is offline
post #3 of 6 Old 10-15-2013, 04:34 PM Thread Starter
Yeah after it warms up but if I try driving before there's no power and it vibrates the whole truck like its either getting no air or fuel as well I'm replacing the glow plugs this week just wondering if anything else could cause it also
post #4 of 6 Old 10-15-2013, 08:05 PM
blue72's Avatar
Feedback Score: 5 reviews
Make sure you use Motorcraft plugs as some aftermarket plugs tend to swell causing them to be difficult to remove.
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #5 of 6 Old 10-15-2013, 08:11 PM
blue72's Avatar
You can easily test the GPs if the harness is good BTW. If you have a volt meter you can check the ohms of each GP at the harness plug in each valve cover.
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
blue72 is offline
post #6 of 6 Old 10-16-2013, 01:42 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
FYI the stock glow plug relay fries itself pretty quick. stancor is a good upgraded relay
i second motorcraft plugs only, the last thing you want is to break a tip off of a glowplug and have it fall in the head.
synthetic oil on your next change is a good upgrade as well.
5w-40 definately helps the truck start easier.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
