identify this van engine component - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-11-2013, 06:35 AM Thread Starter
Question identify this van engine component
hi i received a used van engine yesterday and noticed a few changes from the F series models. For the most part, its just brackets, a manifold and valve covers that need to be swapped over except for one item. On the passenger side, it actually looks like it is a hose/fitting connected to the lower corner of the head in the front...just behind the alternator bracket. what is that ?
lght1 is offline
post #2 of 12 Old 10-11-2013, 06:49 AM
c69ss396's Avatar
exhaust pressure sensor?
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 12 Old 10-11-2013, 07:16 AM Thread Starter
hi that is in its usual place. this looks much larger and has a rubber hose..maybe 5/8ths connected to it and is routed topside. the truck just has a plug in its place.
lght1 is offline
post #4 of 12 Old 10-11-2013, 07:19 AM
c69ss396's Avatar
is it a map sensor? I have never dealt with vans so its a shot in the dark...
c69ss396 is offline
post #5 of 12 Old 10-11-2013, 07:24 AM Thread Starter
hi this is a large fitting...reminds me of lines that were used on gas engine air pumps to push more air into the exhaust stream for the cat converter...back in the day. apparently not used on the f series as it is plugged.
lght1 is offline
post #6 of 12 Old 10-11-2013, 07:38 AM
timmyboy76's Avatar
its the coolant outflow port for the heater core?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 12 Old 10-11-2013, 07:40 AM
timmyboy76's Avatar
yours may have been plugged from OP since they didnt want to change out a bad heatercore.
What your describing is exactly where i'm tapped into, to feed coolant (for heat purposes) to my wvo system.
Name:	coolant outlet.jpg
post #8 of 12 Old 10-11-2013, 07:40 AM
CSIPSD's Avatar
Its a coolant passage... Pictures go a long way my friend...
Name:	van motor.jpg
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 12 Old 10-11-2013, 07:45 AM
c69ss396's Avatar
very true I hate guessing...
c69ss396 is offline
post #10 of 12 Old 10-11-2013, 08:09 AM Thread Starter
hi
it seems to be utilized just for the e series. where does it go to after going topside?
lght1 is offline
