a couple questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-11-2013, 05:17 AM Thread Starter
a couple questions
ok guys I am parting out a blown 2000 7.3, I took the idm off and the computer out and am going to sell them. Questions are my e99 has the xle4 computer so I would probably want to sell it and keep the 2000 model computer? Also I am not sure what idm is in my e99 but the 2000 is a idm-120. Should I change them as well or just leave the idm alone? Thanks for the advice in advance
Early 99' F250 7.3 CC 4x4 XLT,
Mods: 02' headlight conversion, 02' lariat rims, BFG A/T's KO
, straight pipe, PHP Phoenix 65tow, 80econ, 100perf, high idle, leveling kit.
emoryemt-i is offline
post #2 of 7 Old 10-11-2013, 06:56 AM
CSIPSD's Avatar
PCM swap would be fine, wont gain you any HP persay, but the 2000 NVK code will be easier to tune with more options.
The IDM is the same, the only thing you will gain is if its newer, IE lower miles.
If your sure you have a E99, and the truck your parting out is good/low mileage, I would swap the injectors out. Yours has AB's which are 120ccx1000. The AD's are 140ccx1000.
You could also swap the 15* hpop out of yours for the 17* HPOP...
Between injectors and HPOP you could pick up 10-20hp with a chip.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 7 Old 10-11-2013, 10:50 AM Thread Starter
Thanks for the advice. the #6 injector is no good and motor is knocking in parts truck. I havent thought about the hpop. Parts truck is at 248000 and my truck is at 225000 so nottoo much different in mileage. Not sure what to do injector wise. May pull the good ones and try and sell or save them for the time when mine go out. I have pulled the turbo to update mine with. Next is pulling axles out and tranny and transfer case.
post #4 of 7 Old 10-11-2013, 10:56 AM
CSIPSD's Avatar
I would NOT waste time swapping turbo crap over. You will gain NOTHING.
Joe
CSIPSD is offline
post #5 of 7 Old 10-11-2013, 11:27 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
If you do end up swapping turbos ill take your e99 spyder.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 7 Old 10-11-2013, 12:18 PM Thread Starter
Thanks for the turbo info i was not aware of that I thought it was a bigger turbo therefore gain a little.... I guess it will just try and sell the late style and keep mine.
post #7 of 7 Old 10-11-2013, 12:25 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Is the tranny from the parts turck an auto or a manual? If its manual id be interested in it.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
