How to wire 1.5k mod - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-10-2013, 06:00 PM Thread Starter
Ther are lots of threads about the 1.5k mod but none say how to wire it. Witch wire on the icp sensor is it and also I want to wire it to a switch. Thanks
powersmok is offline
post #2 of 18 Old 10-10-2013, 08:06 PM
CSIPSD's Avatar
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 18 Old 10-11-2013, 04:46 AM Thread Starter
Um so how do you wire it?
post #4 of 18 Old 10-11-2013, 07:51 AM
CSIPSD's Avatar
Its been 10 years or so since I dicked with ICP mods... Its not the right way to mess with the truck.
However if you google 10k mod, its more or less the same, just different resistor values.
Joe
CSIPSD is offline
post #5 of 18 Old 10-11-2013, 03:16 PM Thread Starter
Ok I just need to know the color of the wire to put it in and how to put it in
post #6 of 18 Old 10-11-2013, 03:33 PM
timmyboy76's Avatar
if wanting it off a switch, run the 2-wires back to cab, and havethe resistor soldered in one of the wires...grey/red, blue/grn
Diesel Movies - I install a 10k resistor in the ICP sensor of a 2001 F250 7.3L Powerstroke Diesel.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 18 Old 10-11-2013, 03:34 PM
timmyboy76's Avatar
install resistor between gry/red and blu/grn wires.
post #8 of 18 Old 10-11-2013, 03:51 PM Thread Starter
Ok how do I put that on a switch?
post #9 of 18 Old 10-11-2013, 03:55 PM Thread Starter
Ok I have a early 99 and I guess my wire colors are different. Here's what I have yellow/red brown/white and green/light green
post #10 of 18 Old 10-11-2013, 05:28 PM Thread Starter
Found it out here is the procedure for everyone wanting to do a resistor mod for e99
Locate icp sensor insert resistor into green wire through insulation
Run lead off other end of resistor to switch if using a switch
Run other lead off switch to yellow /red wire
then clean up loose wires
Do not cut any factory wires
With the 1.5k throttle response is very snappy and has kinda rough lope
