Just got my 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-10-2013, 05:22 PM Thread Starter
Just got my 7.3
Hey guys just got my 7.3 this week. This is my first 7.3, i previous own 05 6.0 and 07 6.0 (up for sale now). this one is a keeper as i always wanted a dually. Okay now with the f350, it is a 1999 (03/99) with 237,000 miles, owner said transmission has been rebuilt 15k ago, and has a check engine light for ICPS sensor?? I have no clue what that is, and it also has bad ripped interior. Why did i buy this one? i will in the future change interior to the newer style, and for a great price he offered i could not pass up. I have some questions and things i want to do to it, if you guys can help i will appreciate it as I'm a noobie
Concerns:
The power steering is not working and see leakage from the rack n pinion?
The brakes shakes when im slowing down from 50+ mph
Transmission shifts a little hard when gasing it, but when ride normal on throttle it shifts smooth, the owner said when he rebuild the transmission they also put in a converter??? and it suppose to shift a little hard?? and theres a super chip in it
What should I do as I just got the truck?
I was thinking changing the oil, plugs, filter etc. what is necessary to do when first bringing this home?
Things I want to do, planning on
MBRP turbo back or should i look into something else
Programmer, what kind should i get?
Pyrometer
is there anything I need for the motor?
05-07 from conversion
08 tailgate and bumper
lift kit, dont know if i should do a 6" or 8" (want to get some 22)
22.5 alcoa wheels
King Ranch interior if i find some at the junk yard lol
Thanks guys!
heres the truck
turbocharge916r is offline
post #2 of 7 Old 10-10-2013, 05:27 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
First thing I would do is change all fluids and filters and it sounds like you need a brake job with new rotors.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 7 Old 10-10-2013, 06:11 PM Thread Starter
Thanks! I got pads today, I guess I'll grab some rotors too
post #4 of 7 Old 10-10-2013, 06:18 PM
Quoted: 270 Post(s)
Yea, you could probably have yours turned but I would just replace them if I were you.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #5 of 7 Old 10-10-2013, 06:33 PM
Remove the superchip ASAP.
That is probably causing your hard shift.
Invest in a good multi-position chip with tuning from a good tuner. DP-tuner, PHP Hydra, TS-6 posion with tunes from companies such as Gearhead, Tony Wildman are all good choices and can actually improve your shifts with much more power than the superchip.
Change all your important fluids, Might be worth it to drop it off at a good diesel shop and them replace everything. Rearend fluid, antifreeze, oil, trans fluid, brake, transfer case.
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #6 of 7 Old 10-10-2013, 07:53 PM
TSbeanspowerstroke's Avatar
in regards to your CEL with the icp, it stands for injection control pressure, it reads the pressure you get from your hpop. also ditch the superchips programmer and I would recommend a chip from Beans diesel performance or gearhead.
also sounds like you need a new powersteering pump.
2000 Ford F250 7.3 4x4 158k miles. MODS: Beans Tunes, 4" exhaust, custom twin intake, boost fooler, ported housing w/ Clays 11 blade billet compressor wheel, foil delete, glowshifts 3 in 1 gauge, AIH delete, bellowed uppies
Future mods: banks intercooler, coolingmist, 6.0 trans cooler, BWD blue powder coated valve covers, BWD coated exhaust manifolds.
TSbeanspowerstroke is offline
post #7 of 7 Old 10-11-2013, 07:29 AM
[QUOTE=turbocharge916r;6884761]
Yeah, make sure you get some good quality spark plugs for her. LOL j/k I hope she last you a long time...
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
