compression test question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-10-2013, 10:37 AM Thread Starter
Question compression test question
hi
the engine i bought came today and looks quite nasty; looks way worse then my dusted engine with 250k on it.
the donor engine , e series, has quite a lot of caked oil under and around lower part of cover. this leads me to believe that this engine had been severely neglected. paint under valve cover is flaking due to long period of immersion in oil
before i send it back, i would like to do a compression test. the engine is on a pallet but looks like i cannot use a starter to turn it over.
can i turn it over by hand?
Also, since i have a single AD injector and this engine has none installed, can i simply use the single injector one cyl at a time testing as i move inj from one cyl to the other?
lght1 is offline
post #2 of 8 Old 10-10-2013, 01:44 PM
Solid98's Avatar
Quoted: 9 Post(s)
I would think a leakdown test would be in order. If you can't use a starter, you can't really do a compression test.
I don't even know if you can do a leakdown on a diesel.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #3 of 8 Old 10-10-2013, 02:29 PM Thread Starter
hi
i will have to see if the flex plate will turn..its setting awkwardly on a pallet.
i could just kick myself for buying this thing.
lght1 is offline
post #4 of 8 Old 10-11-2013, 06:59 AM
CSIPSD's Avatar
Is it low mileage? Do you have a turbo with it?
Its extreamly hard to clean a van motor when its in it... There is just not alot of room to get a washer wand in there. Would you rather they pressure washed it and hid the dirt?
I think your over thinking this...
Mileage on the motor?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 8 Old 10-11-2013, 07:21 AM Thread Starter
HI I hope so... slept maybe 2 hrs last night mulling this over. Mileage is reported to be 120k..and from a '99 e series. I think the valve cover leaks were from someone replacing injectors or glow plugs and because of the tight space, didnt get the v-covers down good. I was told the van was last use for recreation - towing 4 wheelers and such, that the dust and oil met up and made grease. I ordered a compression gauge and powerstroke adapter yesterday and will test engine next week. There is no turbo or hpop...nor injectors. No biggie as all of my stuff works fine.
lght1 is offline
post #6 of 8 Old 10-11-2013, 07:46 AM
timmyboy76's Avatar
got nothing to lose bud, but time. Throw it on in there and hope for the best.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 8 Old 10-11-2013, 08:11 AM Thread Starter
hi
..and money. i am not installing so in this case..a lot of money if it runs like it looks.
btw...getting quite a few quotes from southern yards on engines today. so far..all have compression numbers and pics. one sent a pic of it installed in truck...vin nmber also so can verify mileage.
lght1 is offline
post #8 of 8 Old 10-11-2013, 08:16 AM
timmyboy76's Avatar
Originally Posted by lght1 View Post
hi
knock on wood, but mine looks like shiat, but runs great....anyhow, your best bet IS to find a motor, when looking for one, thats still in a truck/van..etc
