engine swap, frx question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-09-2013, 07:37 PM Thread Starter
Question engine swap, frx question
hi we are about to swap out my dusted mill for a low mile van engine. sometime ago i bought a riff raff frx but never got around to installing. well now is the perfect time for whole bunch of different things to get installed. my question is... with the frx, can i stop using the LL for #8 ?
lght1 is offline
post #2 of 7 Old 10-09-2013, 07:44 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
yes you can get rid of the long lead.
if you dont have a high pressure oil crossover id look into getting that as well.
more even oil flow between the heads.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 7 Old 10-09-2013, 07:46 PM Thread Starter
hi thanks. i thought i read somewhere that the so called LL cure, could be left out.
lght1 is offline
post #4 of 7 Old 10-09-2013, 07:52 PM
Quoted: 289 Post(s)
ya the truck will run fine without the long lead injector
post #5 of 7 Old 10-09-2013, 08:14 PM
timmyboy76's Avatar
why go thru the trouble, wont hurt to leave it, either.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 7 Old 10-10-2013, 06:38 AM Thread Starter
hi no trouble pulling it as these inj were replaced in april and are being swapped to new engine anyways. is their an advantage to running all ADs over the AE in 8 ?
lght1 is offline
post #7 of 7 Old 10-10-2013, 07:29 AM
timmyboy76's Avatar
only issue i see is that the "cackle" will be morenoticeable. Mine bangs away purdy good...(all ad's).
