6" lift on Regular Cab - Ford Powerstroke Diesel Forum
Old 07-07-2008, 12:05 PM
Send a message via AIM to blizzardwarrior7
Does anyone have any pictures of a 6" lift on a regular cab 350? Or even a 250? Do you have have to modify the front or rear driveshaft to make a 6" lift kit work well? Also, do you need brake line extensions?
Old 07-07-2008, 02:47 PM
no brake lines needed, i helped to a 8" conversion from a 6" pro comp kit on a 03 4 door longbed, had stock brake lines, 8" came with a carrier bearing drop kit and a driveshaft spacer, to lengthen the front, but i would recommend the carrier bearing drop on the 6"
Old 07-07-2008, 04:18 PM
I just did mine today, 6" on a regular cab F250. No driveline mods needed and brake lines are plenty long enough. I will post pics tomarrow as it is getting to dark to take them.
Old 07-07-2008, 07:00 PM
yea, it didnt seem like it at first, but after a few days of the 6" lift, there were odd vibrations and stuff, that were solved with the carrier bearing drop
Old 07-07-2008, 07:16 PM
There is a carrier bearing on the regular cabs?
Old 07-08-2008, 07:24 AM
Hopefully someone will get some pics up soon .
Old 07-08-2008, 07:27 AM
One of our local guys.
Another happy customer
Old 07-08-2008, 07:45 AM
http://i278.photobucket.com/albums/k...r/100_1069.jpg
Old 07-08-2008, 09:55 AM
Originally Posted by black99stroker View Post
Thats a good lookin ride!
Old 07-08-2008, 07:56 PM
Whats a good size tire to run on these trucks with a 6" lift, and the same ? with a 5" lift? I know 37"s fit but dont 37"x12.5s look too skinny?
