Coolant Capacity Help!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-08-2013, 04:01 PM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
I did the whole Gooch's coolant flush procedure to flush all the old coolant out of my truck (draining block plugs, etc.). I installed a new water pump, thermostat, and hoses when I was done. I installed 6 gallons of coolant (3 gallons of Prestone ELC and 3 gallons of distilled water) and it shows as full. I drove the truck, and even turned my heater on to full blast. Heater is getting hot. But my degas bottle is still full with only 6 gallons in it.
I thought the truck was supposed to take more like 8 gallons of coolant/distilled water. What is the deal? Is 6 gallons actually normal, or do I need to get this thing to burp somehow? I haven't driven it a lot, but I figured I'd driven it enough to get everything flowing.
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #2 of 4 Old 10-08-2013, 04:10 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
it should take 8 gallons, thats what mine was when i flushed it.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 4 Old 10-08-2013, 04:18 PM
Two gallons probably didn't drain out and stayed in the motor
late 99' F350, Crew cab, SRW, 4guage pillar pod, combo driving/fog lights, 55w backup lights, drivers side battery isolation mod,6637 intake
coot1 is offline
post #4 of 4 Old 10-08-2013, 04:20 PM Thread Starter
SJB
SJB's Avatar
Quoted: 2 Post(s)
So if this thing is supposed to take 8 gallons, is there any tips to get this thing to suck in the fluid from the expansion bottle? Will it just start burping over time of driving?
I wasn't on perfectly level ground when I was flushing with distilled water (was in my driveway which is a little slanted). But I did drain the block plugs along with the radiator. Don't know if there is a possibility of having 2 gallons still up in there?
SJB is offline
