- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Test and tune questions
Ok so I want to turn up the power more then what I have now.My questions are:
1) Is there a way to test the HPOP to see if its up to specs(pressure range) 2) Test the fuel pressure to see if its up to specs 3) Any tuning up that should be done first I know that my engine has the PMR rods and I am not wanting to excede the power that they can take but I am tired of these sh*tbox little cars and these gasser trucks that just pull from me all the time. I used to drag race and I know that my truck would be lucky to pull anything better then a 17.0 and I see some of the guys on here that have trucks running alot better the that. I know that my truck has more in it just with the mods I have now. Any suggestions on this?? |
| Sponsored Links |
well you can get a high pressure gauge and put it on the oil rail and see how much pressure your hpop is putting out?and find a gauge for your fuel boil.or find a frend with a good scan tool and check it, that way.but it sounds like something is wearing out.IPR O-RINGS?how many miles do you have on your truck?
Your superchips should have a code reader function. If you dont have any ICP codes then you dont really have an issue. Some HPOP's run higher then others, but with the superchips programing you should not see anything that great with ICP pressures anyway. Your right there in AZ... Talk to Dennis at ITP, and order up AE, then you can watch and data log anything the PCM can look at, run and test about anything a Ford shop can... Best $300 you can spend on your truck! With 35s and stock 3.73's its going to feel a bit laggy... Your boost numbers are not that bad for a superchip, with a good chip you should see near 25-28 psi. These trucks will run fine with anywhere from 30psi to 75psi of fuel pressure, they are not dependant on fuel pressure for power. Check it, but if its at 55 or better at idle its fine. |
| Sponsored Links |
