Old 07-04-2008, 06:18 PM
deere4440 deere4440 is offline
A little help
I want to install a coolant filter. I found one at dieselsite, that i'm wanting to buy. My question is, i was told i should update to a 203 thermostat, but on dieselsite, there website read you can't do that. Something about long and short stem thermostats. Do i have to change the housing or what? I guess i'm just confused, need a little advice?
Old 07-04-2008, 06:25 PM
RC51 RC51 is offline
cj41foleyisathief
No just get the one for your year truck. the only short/long that I know of was early water pumps.
Old 07-05-2008, 03:34 AM
Old 07-05-2008, 08:57 AM
NCHornet NCHornet is offline
Powerstroke Techie
WHAT??????? You don't need a 203 thermostat to run a coolant filter!!! Has nothing at all to do with it. Way back when I bought the kit from Bob ( Dieselsite) for $65 but now that he is asking so much more I wouldn't waste my money. Just buy the parts yourself for about $30. If you do use Bob's kit don't use his ball valves, go to lowes and get some gas ball valves, much better than those cheap ones and they seal 100%. I mounted mine down behind the drivers rear tire, there is a cubby hole there that is prefect and protected, but you will need two of the gas ball valves for changing filters. I also see no difference 8 degrees makes a difference on coolant temps. If you have any ? PM me.
NCH
