Balljoints question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-07-2013, 02:25 PM Thread Starter
CoalRollinRoosterCruiser's Avatar
Balljoints question
Hey ya'll got a question.
Earlier this summer i put new balljoints on the truck. They're the Raybestos joints.
During the install process, due to some miscomunication with the buddy who was helping me, the upper balljoints got torqued too much. The uppers got torqued to 150 ft/lbs (which is what the bottom is suppose to be torqued too) as well as the bottom to 150.
Anyhow, i didn't realize any of this till it was all back together, and realized i had memory steer.
Well, due to me being so busy with work, i haven't had the time to tare it all apart and retorque them to what they're suppose to be so i can get rid of the memory steer.
They have approx. 2500 miles on them now. Well i finally have the chance to tare it all back apart now while im doing front brakes.
Are the ball joints still ok? can i just remove the knuckle , and then reinstall the knuckle and torque the ball joint nuts to the RIGHT torque specs?
Or have the balljoints been ruined by having 2500 miles on them torqued to the wrong amount?
Ready to get rid of this memory steer, just hoping i haven't ruined the joints.
Thanks in advance!!
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #2 of 5 Old 10-07-2013, 02:36 PM
usnavyad's Avatar
Feedback Score: 3 reviews
I'll be honest I didn't even torque my ball joints on my 99 lmao I'm sure they are fine just a bit tight if anything.
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 5 Old 10-07-2013, 07:06 PM Thread Starter
Thanks! I sure hope they are. I figure they are, just wanted to make sure
Sent from AutoGuide.com App
post #4 of 5 Old 10-07-2013, 07:40 PM
TSbeanspowerstroke's Avatar
what i did was count the threads on the old ball joints before i removed them and then just made sure i tightened down to the same threads on the new ones, but its to late for that now, i wouldnt worry about them being to tight! did you remove the little collar that sits inside the whole or atleast make sure it moved freely?
2000 Ford F250 7.3 4x4 158k miles. MODS: Beans Tunes, 4" exhaust, custom twin intake, boost fooler, ported housing w/ Clays 11 blade billet compressor wheel, foil delete, glowshifts 3 in 1 gauge, AIH delete, bellowed uppies
Future mods: banks intercooler, coolingmist, 6.0 trans cooler, BWD blue powder coated valve covers, BWD coated exhaust manifolds.
TSbeanspowerstroke is offline
post #5 of 5 Old 10-27-2013, 08:43 PM
Whats the collar for?
greenie is offline
