deal or bad idea? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-07-2013, 01:50 PM Thread Starter
miked.'s Avatar
deal or bad idea?
may have found a six position chip cheap. same exact truck as mine. owner is trading in on a new truck. is there something that could go wrong by using it on my truck? any draw backs? just wondering. only want the trailer tow and economy. don't want to spend 400.00 plus just for those two.
miked. is offline
post #2 of 7 Old 10-07-2013, 02:00 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Yes plenty can go wrong depends on if both ECM are the same codes and how do you know what's really on that chip?
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 7 Old 10-07-2013, 02:03 PM Thread Starter
miked.'s Avatar
good enough, not worth the risk. thanks
miked. is offline
post #4 of 7 Old 10-07-2013, 02:05 PM
usnavyad's Avatar
Np if the ECM are the day if say try it but if they are not the truck will run but you will def know something is wrong!
GPDA's other shawn
usnavyad is offline
post #5 of 7 Old 10-07-2013, 03:10 PM
heisman01's Avatar
Quoted: 51 Post(s)
If it's cheap enough buy it and get it reflashed if your PCM numbers dont match(only thing that would be a problem or if he has an auto you have a 6speed)
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #6 of 7 Old 10-07-2013, 03:13 PM
Raul@Stealth Automotive's Avatar
what type of chip is on it? unless you can confirm that you both have the exact same PCM i wouldnt do it...
Raul@Stealth Automotive is offline
post #7 of 7 Old 10-07-2013, 04:56 PM Thread Starter
miked.'s Avatar
don't think i will mess with it. maybe one day i can get one for my truck.
miked. is offline
