Glow plugs - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-06-2013, 04:23 PM Thread Starter
f3507.3's Avatar
Glow plugs
New to diesels, would my engine turn over faster of I got new glow plugs
Sent from AutoGuide.com App
1999 f350 7.3 lariat
2013 f150 5.0 stx
f3507.3 is offline
post #2 of 8 Old 10-06-2013, 05:35 PM
timmyboy76's Avatar
wont turn over any faster, but if you had a few bad plugs, the motor would definitely then, fire off quicker, if bad gp's were replaced with OEM gp's.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 8 Old 10-06-2013, 05:47 PM
TSbeanspowerstroke's Avatar
if you have trouble starting in cold weather then you most likely need new glow plugs, they help raise the temps in the cylinder so when you have your compression cycle the air is hot enough for the fuel to combust.
2000 Ford F250 7.3 4x4 158k miles. MODS: Beans Tunes, 4" exhaust, custom twin intake, boost fooler, ported housing w/ Clays 11 blade billet compressor wheel, foil delete, glowshifts 3 in 1 gauge, AIH delete, bellowed uppies
Future mods: banks intercooler, coolingmist, 6.0 trans cooler, BWD blue powder coated valve covers, BWD coated exhaust manifolds.
TSbeanspowerstroke is offline
post #4 of 8 Old 10-06-2013, 06:32 PM
BigD214's Avatar
Is there any test you can run to determine if you have bad glow plugs?
BigD214 is offline
post #5 of 8 Old 10-06-2013, 08:03 PM
timmyboy76's Avatar
can test the gp's and the injectors...
post #6 of 8 Old 10-07-2013, 06:13 AM Thread Starter
f3507.3's Avatar
Thanks guys
2013 f150 5.0 stx
f3507.3 is offline
post #7 of 8 Old 10-07-2013, 06:17 AM
BigD214's Avatar
How do you know if your glow plug relay is going out?
BigD214 is offline
post #8 of 8 Old 10-07-2013, 10:35 AM
timmyboy76's Avatar
gpr-led mod will tell ya
