Old 07-02-2008, 01:18 PM
tubular031 tubular031 is offline
External Trans filter
I see kits for 150 to 200 bucks out there for transmission filtering. What makes that so special? I can get some brass hose barbs a little line and a filter head for maybe 30 bucks. Now depending on the filter 5 to 20 bucks. So maybe 50 bucks total? What makes the expensive kits worth the extra money?
Old 07-02-2008, 01:38 PM
badazzstroker badazzstroker is offline
go to ford they have the full inline filter kit for 40 buck comes with everything you need
Old 07-02-2008, 08:13 PM
f250power f250power is offline
Are you talking about that little microfilter ?
Old 07-02-2008, 08:17 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Better yet if you have that filter remove it. It clogs up and causes transmission problems.
The shop that built my trans removed mine for this reason. Since that filter has been removed, I have lower trans temp readings, and have not had any problems with the trans.
Old 07-02-2008, 08:25 PM
I figured it may cause something like that, no experience with it myself, just looks like it.
Old 07-02-2008, 08:33 PM
Well what happens is alot of people don't realize it is there. So when they service the trans they change that filter. But they forget the external filter. It clogs up and burns up the trans. Also it restricts the flow of the fluid. I have talked to alot of transmission shops they all recommend to remove it.
Old 07-03-2008, 07:13 AM
What about a kit like this
http://www.dieselsite.com/index.asp?...ROD&ProdID=761
he says that there is a bypass to keep the flow from cutting off the tranny? sounds good but 175 bucks? sounds steep.
Old 07-03-2008, 11:39 AM
CSIPSD CSIPSD is offline
Thats why the filters cost more, because of the filter heads, you need that pressure bypass... The Diesel site kit is the one I would run!
Old 07-03-2008, 12:07 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
+1 more for the Diesel site kit.... its the one im gonna run in my own rig
Old 07-03-2008, 12:21 PM
WHAT?!? you are not going to run the one you sell on your site? what up with that?
