Old 07-01-2008, 09:08 PM
turbolariat turbolariat is offline
Send a message via AIM to turbolariat
Mods to get smoke!
i have a question, with the mods i have so far should i be seeing any more smoke comin out of the exhaust? if so i have none just the little bit when i get on it but only at first.
i see alot of your guys videos on here and just giving it a little throttle and smoke just roars out.
if not with what i got, what else would i need to get the smoke rollin.
thanks
dave
Old 07-01-2008, 09:33 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
With the mods listed in my sig I can easily blow a ton of black smoke, if I floor it, it will smoke black from 0-35 or 40mph, than it turns a greyish color. Lose the K&N filter!!!
The secret is to overfuel the engine, so get a chip with a tune that has really heavy fueling. you'll get even more smoke if you have a clogged air filter .
Of course, smoke isnt everything, it usually does signify that your truck is putting out some power, but it doesnt need to smoke to put out power.
Old 07-01-2008, 09:35 PM
Cj Ford Cj Ford is offline
chip it ... it will roll the coal unless you use Banks tuning
my old superchips 1805 even made decent smoke in the performance setting ... not near what Tony's extreme does though
Old 07-01-2008, 09:39 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
you need injectors. they are the best way to get dark, thick smoke
Old 07-02-2008, 04:02 AM
Southpaw Southpaw is offline
1/20/2013
I agree chip it. You're truck is still really stock.
Some say 10 k mod pruduces a little more smoke, but not what you're looking for.
Also remember that smoke is unburnt fuel and wasted power. A smoking truck does not mean a powerfull truck
Old 07-02-2008, 04:21 AM
smitty16s smitty16s is offline
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
Use a boost regulator...it fools the map sensor into thinking your truck is only pumping 21 or so pounds of boost....so your truck wont defuel....thus burning more fuel.
Theres a couple of links on this site about a diy, and one from itp diesel...i use a diy and its great.
Old 07-02-2008, 06:27 AM
badazzstroker badazzstroker is offline
yea,you dont have the mods in your sig to make smoke.you need to dump more fuel but just like everyone else say, black smoke is wasted hp.but it does look cool!
Old 07-02-2008, 09:21 AM
thanks guys.
hey Chris, you said dp turners are the way to go right. i will eventually get one as soon as the cash flow arrives.
as for the intake, i have the air box modified for more air flow until i get the the money for a stage 2 intake.
Old 07-02-2008, 09:26 AM
broncrider broncrider is offline
ya the best way is to get the custom tunes with the smoke setting. my ol' stroker will roll coal when i lug it on smoke or wot one the daily tune. key to smoke is a lot of fuel
Old 07-02-2008, 09:52 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
thank you
