  #11 (permalink)
Old 07-03-2008, 04:46 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
here you go: Stealth Automotive. Superior Compressor Wheel
  #12 (permalink)
Old 07-03-2008, 07:10 AM
sirnunya sirnunya is offline
here is the original wicked wheel:
http://www.dieselsite.com/index.asp?...PROD&ProdID=47
  #13 (permalink)
Old 07-03-2008, 09:11 AM
caryt caryt is offline
Install is easy just don't remove the turbo! Under 1 hour on the truck.
Cary
  #14 (permalink)
Old 07-03-2008, 10:17 PM
Weiss1 Weiss1 is offline
Thanks for the great info you guys.
Cary.....under 1 hour
why can't you live closer!
  #15 (permalink)
Old 07-03-2008, 11:00 PM
DieselGod DieselGod is offline
Talking Turbo flutter
Lyle, give Alamo a call in Calgary...yes the guys who you got the MEP turbo from...they are also huge into automotive diesel performance!
  #16 (permalink)
Old 07-04-2008, 08:13 AM
Their is a guy that does it in like 15 min on utube.
  #17 (permalink)
Old 07-05-2008, 11:26 AM
06pwrstrokerbullitt 06pwrstrokerbullitt is offline
So to install the WW you dont remove the turbo or anything?
  #18 (permalink)
Old 07-05-2008, 11:34 AM
Also if I have access to a 7.3 van turbo will this fix the surge, or what are the benefits to a van turbo?
  #19 (permalink)
Old 07-09-2008, 10:30 AM
Anybody????
  #20 (permalink)
Old 07-09-2008, 10:38 AM
CSIPSD CSIPSD is offline
Van turbo will help with surge due to the larger 1.15 housing. Be warned, that 1.15 can be a bit slow to spool at some elevations. A Van turbo and a WW should be a good combo.
